Peripherals new keyboard suggestions?
Discussion in 'Hardware' started by stormbringer500, 30 Apr 2014.
  1. stormbringer500
    stormbringer500 What's a Dremel?
    6 Jan 2010
  2. Scott C
    Scott C Minimodder
    25 Mar 2001
    I take it based on the one you're looking at that you're after a 'gaming' keyboard?
    I've been looking myself and, if I can resist the lures of a mechanical keyboard, I think I might go for the Corsair K50 and see how I get on with it :)
    It also looks to be roughly the same size as the G11
  3. Teelzebub
    27 Nov 2009
    I had one of the ones you linked they're ok but I found the side keys broke easy, Personally I would get a mechanical that's all I use now especially for gaming
  4. stormbringer500
    6 Jan 2010
    Well took a while to decide but just ordered the Corsair Vengeance K95.
  5. Scott C
    Scott C Minimodder
    25 Mar 2001
    Let us know how you get on, I've also had my eye on that one :)
  6. GeordieGoose
    GeordieGoose What's a Dremel?
    18 Oct 2010
    I used that keyboard for a while before swapping to This Logitech not that I paid £145 for it.
    The keyboard is quite some size mind. I liked the board but I would maybe save up a little and get a mechanical board. You wont look back.
    I also had to send it back for replacement a few years back due to it entering random characters but I'm sure they fixed that in a later revision.
    Just re-read the post haha my waffle wasnt needed
  7. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I personally think the CM Trigger Z is better than the corsair. Much better features.
  8. Shirty
    18 Apr 1982
    I think you should get a Cougar Attack X
  9. Margo Baggins
    28 May 2010
    Everyone SHOULD get a cougar attack - but they are like hens teeth! they were such a supreme example of a keyboard, they couldn't produce that many, due to the rare earth metals inside.
  10. Shirty
    18 Apr 1982
    Tell me about it mate, I've been on the lookout for another ever since!
    Some say that the rare earth metals inside are worth more than the contents of Fort Knox, and that the solder comprises 98% pure unobtainium.
  11. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Good job, for a moment I was worried you were about to drop £60 on a shiny rubber dome keyboard, but you pulled through :D
  12. stormbringer500
    6 Jan 2010
    Well should be here on Tuesday fingers crossed.
  13. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Don't forget all the contacts are constructed with pure Madeupium. :screwy:
    Good choice I am loving my K90 :thumbup:
  14. stormbringer500
    6 Jan 2010
    Well it has arrived :D
