Windows New Outlook PST but keep old emails?
Discussion in 'Software' started by Nealieboyee, 28 May 2016.
  1. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Hi All,
    I have a friend who uses outlook 2013, and their PST file is currently close to 6GB in size, causing massive slowdowns and hangs in outlook. I would like to create a new PST file for her, but have all the old emails accessible/searchable.
    I'm sure I've done it once before, but for the life of me I can't remember how.
    Creating a new PST is easy, but its keeping the old emails that baffles me.
    Any ideas folks?
    Thanks
    Betty
  2. phuzz
    phuzz This is a title
    28 May 2004
    It's been a little while since I used Outlook, but I think the setting you're looking for is Archiving the email.
    This page seems to tell you the basics. Basically you'll move old emails into an archive file, that will sit below the inbox/sent/etc folders on the left.
    You can set up auto archive, so anything older than (eg) a year will be moved periodically.
  3. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Once you create the new PST, just open the old PST within outlook and it will appear in the navigation pane.
  4. Nealieboyee
    14 Aug 2009
    Thanks guys. Now when outlook starts, it should be quicker as its not opening the larger pst file as the primary pst, yes?
  5. saspro
    saspro IT monkey
    23 Apr 2009
    Outlook can handle 40GB PST's, a 6GB PST file probably isn't going to slow it down that much
  6. phuzz
    28 May 2004
    It still has to load a lot of data, and on a laptop with a spinny harddrive that's not going to be swift.
    Plus, until the mail is archived it'll also be on the server too and that's not going to help.
