Graphics Nvidia 3xxx series thread
Discussion in 'Hardware' started by The_Crapman, 6 Jun 2020.
  1. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    So what do people think is the best way to at least be in a preorder queue for the 3080ti? I'm thinking Scan rather than any of the other price hiking retailers!
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    Based on prices seen throughout the shortage Scan, Aria and Currys are probably your best bet to get one in the same universe as MSRP.
  3. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    That matches my thinking, Currys have been closest to MSRP as far as I’ve seen, though slightly above, Scan prices started out similar and have been creeping up, but not as much as other places.
    CCL, overclockers, Box and most other places really seem to be milking it (though that’s a sweeping statement and therefore there will be exceptions!)
  4. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    So my EVGA 3080 on Ark survival Evolved is sitting at 100% load constantly... this doesn't seem right - it's putting out a lot of heat (80c) and the fans sound like a rather obnoxious bee... The old 970 only sounded like this after a build up of dust so really can't understand what's going on here...
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    100% load is correct, otherwise your framerate would drop accordingly. If you want it to use less power and therefore generate less heat, set a framerate cap or power cap. 80C does sound about right at full tilt.
  6. David
    7 Apr 2009
    Open HWinfo and check your GPU Memory Junc temp - if the VRAM is hitting the limiter it'll ramp the fans regardless of GPU temp.
  7. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Thanks all!
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  9. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I wouldn't bother, you won't be able to get one and they're all be significantly marked up!
    Best of luck for those trying though
  10. David
    7 Apr 2009
    Yeah, it's not like the nvidia nerfs will put off the bulk miners - they'll hoover up as many as possible and, if the nerfs persist, they'll just scalp the cards.
  11. Goatee
    Goatee Multimodder
    19 Apr 2015
    Totally, my 3090 has so far earned my about £440 in BTC at todays prices, based on nearly 2 months mining, using around £60 of leccy to do it. So assuming around £180 a months profit per card you should be on major bank by the end of the year.
  12. Bloody_Pete
    11 Aug 2008
    Thats low according to Nicehash, you should be looking at double that!
  13. David
    7 Apr 2009
    No, you're looking at £200-£230 with a 3090, after electricity costs and assuming no downtime or major fluctuations
  14. oasked
    24 Aug 2005
    My 3070 is averaging around £115/m ignoring electricity costs (~60 MH/s). The 3090 is around 105 MH/S so should be a little less than double.
  15. Bloody_Pete
    11 Aug 2008
    Oh wow, the price has really dropped! Plus I pay half as much for electricity apparently!
  16. Goatee
    Goatee Multimodder
    19 Apr 2015
    Agree, I'm averaging 110 MH/s actual over the past week, normally I'm around 115 but lost some up time due to a network issue.
    I might need to check what I'm actually paying for electric, I may be overestimating.
  17. David
    7 Apr 2009
    13p per kwh here
  18. Bloody_Pete
    11 Aug 2008
    Same which Nicehash calcs as £30 a month...
  19. David
    7 Apr 2009
    Yep - and it is currently estimating £222 monthly profit.
    It jumps up and down with the value of BTC obvs but, apart from the slump last week, it's been roughly estimating that amount for the last couple of months.
  20. Anfield
    Anfield Multimodder
    15 Jan 2010
    Going by whattomine numbers based on a week:
    3090 = $12 per day mining Eth
    $12 at current exchange rate £8.60
    £8.60 x 30 = £258
    Knock off £1 a day for electric
    So yeah, £220 - 230 sounds about right.
