NVIDIA GeForce 6800 GS
Discussion in 'Article Discussion' started by Tim S, 7 Nov 2005.
  1. Firehed
    15 Feb 2004
    No top-end card will have trouble with HL2 at any setting, even midranges like this can max it out no problem.
    I totally am with you bigz - benchmarking isn't as easy as it's cracked up to be. Granted a BPS for several resolutions (start with the highest obviously, if it can play hl2 max at 1600x1200, it can clearly do it below that as well), and a more subjective "here's the best mix of res and quality" is nice to have but a lot less relavent in my eyes, especially with the prominance of TFTs. Of course in theory, bad TFT scaling could almost grant free AA. I'd almost not bother with 1024 anymore, I'd think just 1280 and 1600 will cover most bases. I figure my 1680x1050 is more or less the same as 1600x1200 in the games that support it (a few pixels less, but a wider draw space, in any case it seems to play about the same as that's where I came from).
    The "common sense approach" would seem to be the best mix of effeciency and quality results. If it's unplayable at 1280x1024 (I wouldn't bother with the x960 for 4:3 except in FEAR and other games that refuse to do any other aspect), obviously it won't do 1600x1200, and vice-versa. Before I always liked to play at 1600 because I didn't like for my monitor to switch modes and drop to 60hz and need to be readjusted for squareness, now I prefer running native because it's on a flat panel.
    Guess I don't stand a whole lot of chance at not losing a fortune on my NIB 6800gt again. Maybe I should just go for SLI again (but gah, I'd need another new waterblock......and I'd rather gain back what I can than shell out another $120 or so), seeing as I'd actually get something out of it with FEAR and Q4 and whatnot. Especially considering driver support has increased tenfold since my RMA (and when I got my LCD after the RMA, I stopped running dual-display, but if I can customize a keyboard shortcut for enable/disable SLI like for my display rotation, that wouldn't matter much)
  2. Petor
    Petor What's a Dremel?
    19 Jun 2005
    umm...
    i play fear on at 1024x768 with the graphics on high.... on a 6600gt overclocked out of the box... with no trouble at all... runs smooth as
  3. Tim S
    Tim S OG
    8 Nov 2001
    it depends what you class as 'smooth' - these are 'worst case' scenario settings. I could easily make them much much higher and have the frame rate drop much much lower, but I believe the majority of frames should be rendered above 30 frames per second.
    I've also had this arguement elsewhere on these forums.
  4. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    nice review i like that best playable settings and i hope you guys keep that nice work...
    the card looks good for 200$ not too long ago that was the price of the 6600gt
  5. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    Bigz good luck with trying to make a 6800GT and a 6800GS run in SLI, I just don't see how that would work out.
  6. pillow
    pillow What's a Dremel?
    16 Aug 2004
    newegg has two of the 6800gs in stock, an evga and the XXX just wanted to let you guys know, if you didnt already. what would be a better purchase, a 7800gt or two of the 6800gs' in sli?
    F.B.
  7. Tim S
    Tim S OG
    8 Nov 2001
    I think I'd go with the GT, because there's always the option to upgrade with another GT at a later date.
  8. hitman012
    hitman012 Minimodder
    6 May 2005
    The GT would offer only marginally less performance but with the ability to add in another much more easily. I'd go for that.
  9. Tim S
    Tim S OG
    8 Nov 2001
    I haven't had the time yet - if I get the chance this evening, I'll have a go!
  10. kenco_uk
    28 Nov 2003
    Rough EBuyer all-in prices.
    6800 Std = £120
    6800 GT = £210
    6800 GS = £185
    GS seems to be pretty damn good vfm. I've just recently got myself a 6800 Std because of the drops in prices.
  11. Tim S
    Tim S OG
    8 Nov 2001
    The GS on ebuyer is faster than a GT and close to the performance of the 6800 Ultra. ;)
  12. MidnghtDrgn
    MidnghtDrgn What's a Dremel?
    7 Jul 2005
    Interested in seeing if this works. Running a GT right now, looking at going SLI.
  13. MidnghtDrgn
    7 Jul 2005
    Sorry to bug you Bigz, was wondering if you'd had a chance to test this yet?
  14. Tim S
    Tim S OG
    8 Nov 2001
    No problem, I forgot to post.
    I can't get SLI working at all with the GS and GT installed - I tried several driver revisions with no luck.
  15. l0cke
    l0cke What's a Dremel?
    25 Sep 2005
    So can we use any 6800 cooler on these or what?
  16. Tim S
    Tim S OG
    8 Nov 2001
    yes, uses the same mounts as the 6800 series from what I can see.
  17. herbs
    herbs Nobody but us chickens
    7 May 2001
    Do you intend to review the agp version which seems to be a much lower spec and price? more like the 6600GT price range and a core of 300mhz and memory 700mhz.
  18. Tim S
    Tim S OG
    8 Nov 2001
    I've heard nothing official about the AGP version from NVIDIA.
  19. herbs
    7 May 2001
    :duh: I made a mistake it wasn't the gs I was thinking about when posting the spec and price. But there is suppose to be agp version of the gs soon according a search of the web sites. So going by your statement does that mean unoffically your been told something ;)
Tags: Add Tags
