News Nvidia GeForce GTX 460 photos and specs appear
Discussion in 'Article Discussion' started by Claave, 25 Jun 2010.
  1. Hustler
    Hustler Minimodder
    8 Aug 2005
    Of course a 600w will run it.....you can run a 5870 on a 500w for goodness sake.
  2. alpha0ne23
    alpha0ne23 What's a Dremel?
    31 Jul 2007
    Why dont they use GDDR5 for higher performance ???
  3. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
  4. capnPedro
    11 Apr 2007
    Does anyone remember when Nvidia released the 8800GT? Overclocks to almost the full performance of an 8800GTX but much cheaper, much cooler, requires less power and comes with a single slot cooler? Evolution rather than revolution with a die shrink and some clever design improvements...
    Good times...
    I half expected the GTX460 to be a similar sort of release. Apparently not.
  5. rickysio
    6 Jun 2009
    Mostly because TSMC shat bricks onto nVidia's strategy of creating huge dies and using die shrinks to save their asses.
  6. Guest-16
    Guest-16 Guest
    Well TSMC are governed by the laws of physics and they aren't the only semi-conductor company out there. Nvidia should have done the research a bit earlier like ATI did with HD 4770. ;)
  7. kingjohn
    kingjohn mod this sucker
    22 Jun 2010
    price drop never happen , new gpu same price or more cause its new and not many in stock . intel does same with cpu germany 2 england 1 i think as i type , GTX 470 for me aa on its faster than a ati 5870 for less money nuff said .
  8. Guest-16
    Guest-16 Guest
    I have a question: Why do you keep posting this in every single post you make? It's not even that relevant here.
  9. trek554
    trek554 What's a Dremel?
    11 Sep 2008
    they are using gddr5
  10. Tangster
    23 May 2009
    Banhammer?
  11. hyperion
    hyperion Minimodder
    30 Jun 2007
    The mid-range is getting alot more expensive than it used to be :(
  12. Guest-16
    Guest-16 Guest
    Tempted. Either that or to edit everyone with something funny.
  13. alpha0ne23
    31 Jul 2007
    So whats the going rate these days for an nV shill ??? :rolleyes:
    If the 460 really does use GDDR5 then why is it clocked so low, the bus not wide enough ??? :duh:
  14. Elton
    23 Jan 2009
    Wouldn't a small bus = higher clocks to compensate?
    I have a feeling it's a cost saving measure, no need to get high clocked RAM chips. That or it's intentional crippling.
  15. Guest-16
    Guest-16 Guest
    It's either:
    • Cheaper memory to hit the cost - memory prices have been increasing all round
    • or less memory power hardware to hit the cost and board size.
    • or Nvidia doesn't want it eating into their GTX 470/480 sales with a performance that's too close
    • Supply issue? Demand for fast GDDR5 is high because ATI uses it in everything and NV uses it for GTX 480/470/465 already.
  16. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Assuming the thermals and power consumption are decent Nvidia might finallyhave something that could form the basis of a HD59570 competing product.
  17. trek554
    11 Sep 2008
    its at 3600 so its not really all that low. it could be kept artificially low at this point so as not to eclipse the gtx465 too badly.
  18. Grape Flavor
    Grape Flavor What's a Dremel?
    23 Sep 2009
    Pretty disappointing to see there doesn't seem to be a 384SP part at launch.
  19. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    For us Folding nuts, the key questions are, "what is the ...
    - PPD (Points per Day for the non-Folders among you)?
    - Power consumption?
    - Operating temperature under full load (24/7 use)?
    - UK cost?"
    .... probably in that order :)
  20. NortyOne
    NortyOne NortyOne
    2 Jul 2010
    This does seem a strange marketting ploy. Not only will it quite obviously (if the rumors are actually true) beat down the GTX465 making it kinda pointless, but being capable of GTX470 performance as well surely they are going to not only shoot themselves in the foot, but blow their whole leg off?
    im a little scepticle, but having been watching the GTX 470 for some time with interest this has thrown a curve ball into the mix. My guess is that maybe the card will be designed at making current games comfertably playable where the ATI's are currently thrashing in all areas (ps this bothers me as i am also an Nvidia 'fanboi' lol) due to lack of Dx11 / tessalation support. However, if the Cost is around the £180 mark, then maybe its going to be set to be quite an awesome SLI proposition, as if it can nearly match a 470, surely two will match or even out do the GTX480? i'd like to see SLI for these upon release both stock and overclocked. Maybe then will i consider selling on my 260's
    Either way it seems a little wierd, im going to hold off doing anything till a see them appear
Tags: Add Tags
