Memory Only half my RAM being utilised
Discussion in 'Tech Support' started by specofdust, 18 Jul 2012.
  1. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I hate MSI's BIOS flash utilities....one of them bricked my board -.-
    On topic, it won't boot with 3 sticks? That's really odd. It should certainly boot with any orientation of RAM. It certainly seems a hardware issue but exactly what is currently eluding me.
    Have you tried one stick of original memory plus one stick of vengeance? I'd see if that works. If it doesn't then there's obviously some sort of incompatibility somewhere, likely voltage or timings.
  2. faugusztin
    11 Aug 2008
    Then your memory controller simply can't handle it - 3 modules should work.
  3. noizdaemon666
    15 Jun 2010
    I was thinking a similar thing. Maybe bumping VTT to 1.45 will do the trick, possibly even 1.5. But then those sort of voltages are more likely to cause long term damage so even though it may solve the problem, it may cause more down the line.
