Case Mod - In Progress Paperazzi: July08 MoTM - End of the road :)
Discussion in 'Project Logs' started by acey, 27 Jun 2008.
  1. acey
    acey What's a Dremel?
    6 Mar 2006
    lol i dont consider myself good in using it but its now my fav material. well, if youre using it and you have any questions you can just ask me or anyone else :)
    Mouse pad is still in progress.
  2. acey
    6 Mar 2006
    Some update. Have to stack near-empty spray cans on it so it doesnt bend when it dries.
    Added another layer underneath it to thicken it a little. And bought some stuffs today to finish it off.
    Just for deco purposes. Lol, no, not watercooled mousepad, that would be nonsense. :)
  3. Frido
    Frido Minimodder
    19 Apr 2007
    Nothing's nonsense in this forum dude! :rock:
    Next up is a watercooled mousemat then ;) (C'mon people, who'll be first? :dremel:)
    Nice deco thingies - maybe you could have some clear tubing with slime inside them sticking in and out of the sides of the mat? Would look grossly organic IMO :)
    /Frido
  4. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    ermm watercooled mouse mat frido i was thinking in watercooling my pump and and rads :p lol
  5. acey
    6 Mar 2006
    Lol.. watercool your cooling fans and grills
  6. Cheapskate
    13 May 2007
    You will need to mod your mouse. Mainly into an 'all-terrrain' mouse. :hehe: A full theme casemod will get you more points in a contest, so you are stuck with modding everything now.:D
  7. Frido
    Frido Minimodder
    19 Apr 2007
    LEDS get hot, don't they? (I know they don't get THAT hot, but a bit hot's hot, right? And hot needs to "not-be-hot")
    Throw 'em in the watercooling pool! :) And let the watercooling craziness games begin! *diabolical voice*
    /Frido
  8. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    If your doing case, keyboard, mouse pad, you gotta do the mouse and the monitor tooo!!! Don't tease us lol
  9. acey
    6 Mar 2006
    :D Keep guessing, keep guessing haha
    You'd probably get "invisible light" LED in the end hahaha
    Lol, you'll just have to wait and see what I have next lol. Even I don't know..
    I'll finish up the mousepad by today. Its 3.30pm right now over here and I've done the base color for it after gripping glue. I'll try painting it with poster color instead of red oxide spray (horrible color, shouldnt have gone for it) and then slime it. Hopefully. Gonna get my left calf tatt finished tomorrow so might be taking a few days off after tomorrow.
  10. acey
    6 Mar 2006
    Mwehehehe. 1 more day.
    Painted with minor highlights. Then further highlight with the old brown instead of red oxide that I used for the keyboard (it sucks, I'm gonna need a new can of brown)
    Slimed :D
    I stuffed the 2 cylinders into their place, took me a couple of minutes as the paint and slime tightened the loop a little. Feel its too empty so I pour some slime and additional glue into it. Don't ask me how it's gonna turn out to be when its dried, I got no idea at all lol. We'll just have to wait and see.
    For the plastic tubes, opt for semi-flow look. Since the cylinders are half empty or half full I'll just make it look as if its non functioning anymore.
    I'll need to clear coat them tomorrow and superglue the top covers early. Some patch of purple are not so brilliant right now but once clear coated they'll be extremely shiny. As stated on prev post, I might be taking a couple of days off modding as I'm getting my left calf's tatt finished tomorrow noon.
  11. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    As good as it looks - without a plain surface the mousepad is absolutely useless. :(
  12. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    1 mm acryllic Cheesecake! :D cut it to size and you got yourself a damn fine mousepad!
    love the overall mod acey!
  13. acey
    6 Mar 2006
    Too bad. It works very fine with my mouse when I try it out. :) Now re-define useless for me please :)
    Lol mate, no acrylic for it. I wannit purely out of paper and paper only.
  14. acey
    6 Mar 2006
    Done done done. 3/6 of the set.
    Back and right
    Front part
    One slimy family
    Spiderman.. spiderman..
    Time to go get my ink. I've already got some ideas for the mouse, LCD monitor and speaker base in my head. Be back once I get a back-up mouse :D
  15. Asulc
    Asulc Minimodder
    18 Jul 2007
    Good. I was really hoping that you would do something with the mouse, monitor, and speakers!
  16. acey
    6 Mar 2006
    Heh don't worry i will, was just toying with the idea of a full set in the beginning n now since it'll look weird thought might as well go for it all like what Kenco n the rest said
  17. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Just tuning into this, so I might have missed this aspect of your material usage. I hope it's not too fragile because it really looks good.
  18. acey
    6 Mar 2006
    :D Thx for checking out. No prob so far with all 3 stuffs.
  19. Frido
    Frido Minimodder
    19 Apr 2007
    That picture where you can see the side of the case - there's a round depressing in the middle of the "X" - you could put a cylinder with slime there, just like those on the mouse pad? Would fit the theme well IMO? And by the way, how are you gonna get the mat's surface flat enough, as I see it, the paper's got such wrinkles in it - making it a hell with a mouse?
    Great mod, it just get better and better! :)
    /Frido
  20. acey
    6 Mar 2006
    Not for the side panel. Will make it too.. uh.. bulky with cylinders on it. When I lay the paper for the base I actually get another layer of plastic on top to flatten it. So the wrinkles you see on the pad are actually dents, not bumps. :naughty:
