Planning PC modding with MIG welding
Discussion in 'Modding' started by Amon, 10 Oct 2011.
  1. Amon
    Amon inch-perfect
    1 Jun 2007
    Has anybody considered MIG welding for their mod? I'm talking about fabricating almost everything by welding it together. I know it's not going to work on modern aluminium and composite cases, but does the steel used in run-of-the-mill PC cases withstand amateur MIG welding? (drive bays, motherboard carrier, and other mounts)
    I'm asking this because I have a utterly bonkers PC mod that only an absolute nutter would consider... but it involves welding!:idea:
    All ideas are welcome!
  2. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    composite and aluminium cases are possible to weld with a mig welder, but you need patience. When you can weld lead plates you are ready to go to the next level amon chan
  3. Cheapskate
    13 May 2007
    Tack welds shouldn't be a problem, but trying a full weld will likely burn through.
    Is the MIG rig all you have available?
  4. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Tack welds and body filler should suffice, Cheaps.
    I say go for it!
  5. Teelzebub
    27 Nov 2009
    You can weld thin steel and aluminium with a mig so long as your using the correct gas and wire and you set it up right.
  6. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    I weld thin plate with a mig at work as said your best of with spots and filler its ok to weld of a structural brace or frame as you can work the heat off of it.
