Motherboards pc wont start?
Discussion in 'Hardware' started by Harlequin, 3 Feb 2014.
  1. Harlequin
    Harlequin Modder
    4 Jun 2004
    now either im a noob or something isn't right;
    parents new pc wont do anything!
    gigabyte F2A85X-UP4 , A10-5800K , antec 450w psu
    nothing happens at all when I press the power button ! nothing at all - no beeps nothing!
    except - the psu power switch (internal) is lit and orange?
    any idea`s?
  2. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Did you have it running before?
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
    no - only just finished building it
  4. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Remove everything from the mobo, try to boot with just the cpu and 1 memory stick installed.
  5. rollo
    rollo Modder
    16 May 2008
    Is the bios fully updated to support the fx/ apu range of chips?
  6. jinq-sea
    15 Oct 2012
    I'd say this is highly likely a BIOS update problem :(
  7. Harlequin
    Harlequin Modder
    4 Jun 2004
    the board came with the apu as apparently a functioning unit :(
  8. mrbungle
    20 Sep 2004
    Doesn't sound good if you are getting absolutely nothing when powering on.
    Disassemble and maybe try another PSU.
    If still no action sounds like the boards smoked.
  9. itrush07
    itrush07 Minimodder
    28 Nov 2007
    You can also try another board if you have spare?
  10. jinq-sea
    15 Oct 2012
    Oh - not BIOS then :(
    Sounds a bit more serious. If it's in the case, take it out and build it on the side, just to check for shorts (electrical, not the clothing variety - it's too cold for those at the moment)
  11. GeorgeStorm
    16 Dec 2008
    Trying another PSU would be an easy check if you've got one spare.
    Not wanting to be rude, but have you made sure you've plugged everything in correctly (including the front panel connectors) since I know in the past I've had a moment of panic when nothing seemed to work before finding out I'd connect the power switch to the wrong headers.
  12. Harlequin
    Harlequin Modder
    4 Jun 2004
    Meh dead antec psu it is. ..
    definitely a noob moment for me I think should have checked first! Windows installing on 8gb 2133 cl 10 ram and an ssd
  13. Harlequin
    Harlequin Modder
    4 Jun 2004
  14. AlienwareAndy
    7 Dec 2009
    Give it that Mantle benchmark man.
