Scratch Build – In Progress ****** PHINIX CUBE ******* - the one and only:)
Discussion in 'Project Logs' started by phinix, 3 Dec 2007.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    In the meanwhile you can se what I bought for my cube.. new pair of ram...
    Very original package:)
    TTAAA DAAAAA...!!!
    These leds will light up my cube..mmm...:)
    Pair of nice Crucial Ballistix Tracers in my cube...
    Here's how they light up my Sugo case for now..
  2. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Well a certain amount of heat is generated by the motor in the pump. I don't know why your loop should heat up that much with the pump though. Is the radiator warm to the touch as well?
  3. phinix
    28 Apr 2006
    Yes, it is warm.. but very very low.. I mean maybe 30C.. As far as I understand pump gives away about 10W of heat.. is it possible that this energy would heat up it so much? hose has the same temperature as radiator - little warm. But pump is like 2 times more...
  4. MixWizard
    MixWizard Minimodder
    16 Jan 2007
    from your pictures ivee noticed you havent got any fans attached to the rad to help cool it down, have you tried with the fans on the rad?
  5. phinix
    28 Apr 2006
    Yes, guy from Swiftech told me the same thing.. try to cool it down with the fans and then we will know if the pump is damaged... I need fans now:)
  6. MixWizard
    16 Jan 2007
    Was just a thought, as without something to cool the rad youre just gunna circulate warm water
  7. phinix
    28 Apr 2006
    Yes, but didn't expect that pump will warm up itself like that, you know... it is only 10W.. suppose to to be anyway...
  8. MixWizard
    16 Jan 2007
    Yeh but thats like fan D.B ratings aint always what they say on the box :p
  9. phinix
    28 Apr 2006
    true true...
  10. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    Coming along nicely.
    Yes, fans may help. :)
  11. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Small amount of water, low resistance, you're bound to get some heat build up.
  12. phinix
    28 Apr 2006
    you're right, must getting some heat anyway.. need to buy fans.. already decided to get Noctuas P12... just saving some money to buy them, cause they pretty expansive:eeek:
  13. phinix
    28 Apr 2006
    Hmmmm... I was thinking about this PSU hanging out up there, never liked that option because it would cover all my cpu block and other stuff, so was thinking last night on making some update and I wonder if you guys approve this solution:
    PSU going down, radiator with fans going on one of the sides, drive cage will be redesigned to be smaller. Of course to fit all the stuff down there I would use slim laptop dvdrw - which is so nice:)
    Here's the idea, PLEASE comment it cause I don't actually decided what to do and now is a good time to make a move!:)
    FRONT
    REAR
    SIDE
    So??? what do you think??? I will have plently of space on upper level and no more problem with hanging PSU and its weight...
  14. phinix
    28 Apr 2006
    ooow.. I could rise the mobo tray 1cm more and then I could put PSU up, on its side.. standing up..you know… could gain some more space for future when I may need to add another radiator with fans on other side.. its like begging for it now :)
  15. jhanlon303
    7 Sep 2006
    This is like my Casdon project. Move this, try that, rearrange this. This is what modding is - new ideas at every turn. I love SFF and this project rocks.:rock:
    John
  16. phinix
    28 Apr 2006
    Time for little update...
    After decided to rearrange everything I finished making all mounting cubes.
    These are all 4 cubes for top panel:
    Drilled and threaded inserts fitted nicely with Iron solder:) Little dirty from masking tape glue left on them.. will clean them later...
    Here are those additional "mounting things" I mentioned before - drilled and waiting for hot steamy insert...
    Little dirty too - DREMEL polishing compound;)
    Another thing - here is radiator's.. lets call it - plexi back wall..
    Support holes drilled and ready to cut... using dremel this time, not jigsaw...
    And after..
    and with sanded and polished edges
  17. phinix
    28 Apr 2006
    New drive cage idea, using Zalman coolers...
    And the new place for slim dvd - right on top!!! :)
  18. hawky84
    hawky84 SilentModder
    15 Nov 2007
    Liking the look of things so far
    How are you planning to mount the disc drive to the case?
    Just thinking of how much noise they make when they spin up, would be nice to have it mounted with rubber grommets
  19. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    ....that's agreat idea to use the air flow from the radiator fans to cool the hdd's........
    nice mod and great work so far ...........:thumb:
    *Subscribed*
    Alan
  20. phinix
    28 Apr 2006
    Well I'm going to use my old PSU - Enermax 500W - it has 140mm of length. So I got left 150mm for drive cage. Zalamn cooler have 146mm of width which means there is no way I could put them in, cause adding 6mm for both acrylic walls and some space for cables coming about from PSU.. I have no room for them. So looks like I need to go back to my first mountings of hdds - bungiee rope... New drive cage layout stays, but need to figer out how to mount bungiee rope to those walls (some small hooks or sth?).
    In future if I would like to change PSU to for example Corsair 620W which has 150mm then I have 1cm less than now...:(
    So I would have about 140mm for cables and the whole cage. I assume that 3cm for cables is enough to bend them up... maybe even 2cm. So I have 110-120mm for drive cage. If I use those ropes, I wont need rubber stands to fix to the bottom of the case. I will just screw it to the bottom., cause ropes will absorb all vibs from hdds...
    Will try to make sth like this
    http://www.silentpcreview.com/article39-page1.html
