Other Photos of your computer
Discussion in 'Hardware' started by [KNIGHT], 9 Jan 2010.
  1. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Not being anal here, well, I am a bit, but any chance the OP could clean up his posts and thread title, maybe using capitals and spelling? Just makes it look a little tidier.
    Anywho, on with the pics!!
    This was back when I had my 4870 installed, have a GTX260 now, and well, don't have anymore photos of it, so here's what it looks like...well, almost.
    siliconfanatic likes this.
  2. krazykid035
    krazykid035 Entrepreneur
    13 May 2009
  3. Eggy
    Eggy Minimodder
    8 Oct 2009
    It's fairly empty I guess. Will be replacing those tricool fans and stock cpu cooler sometime in the future.
  4. wyx087
    15 Aug 2007
    you and me, i think they are just not needed. i've even taken off all form of lighting on my case, including the power and HDD LED.
    what is your case? i really like its design and exterior looks remarkably like Antec p182.
    here's my one, nothing special.
  5. flamin9_t00l
    flamin9_t00l 1,000,000,000,000 Bytes Free!
    4 Jan 2010
    Hi, here's my OCed 920 PC
    Must get a new camera, its gettin on a bit.
    64GB SSD + 1TB F3 on the way next week :naughty:
    ________________________
    :rock:CPU: i7 920 @ 3.80GHz (HT on) / Cooler: Titan Fenrir / MB: ASUS P6T SE / GPU: Sapph 4870X2 / Mem: 6GB Corsair Dominator DDR3 @ 1450MHz (9,9,9,24 2T) / HAF 932 / Xigmatek NRP 751 / alpha LCD / 24" iiyama / Win7 HP 64bit:D
  6. unknowngamer
    unknowngamer here
    3 Apr 2009
    Just a quick update with pics.
    I got an Antec 1200 a few months ago with the idea if mounting a 2x120 and 1 3x120 rad on the inside.
    I would gone for a TJ07, like every one else who wants an internal 360 & 240 rad, but
    A) to expensive
    B) I like the 1200 (lots don't though...)
    I've mad a few changes scice I first did it.
    Specs are:
    Motherboard: XFX -MB-X58i-CH19........................CPU: I7 920 D0
    2X GTX 280 in SLi (EVGA&Leadtek) ......................PSU: 850W NorthQ Black Magic Flex Modular
    Case: Antec 1200.................................................RAM 3x 2GB OCZ Obsidian 1600 MHz
    HD: 640GB WD AAKS & 1TB hitachi data drive.
    The GTX's are overclocked to 720/1500/1150, CPU at 3.6
    Cooling. I've kept all 6 stock fans on the 1200.
    2x120mm rear + 3x120mm front + 200mm roof
    Watercooling is made up of the following loop in order.
    Pump : Laing DDC1+ (18w) with XSPC restop
    CPU :Aqua-Computers Cuplex XT Double impact (775 with 1366 kit)
    Rad 1 : XSPC RX240 2x120mm
    GPU1 :EK-FC280 280GTX SLI Watercooling Block
    Fesser SLi connector kit
    GPU2 :EK-FC280 280GTX SLI Watercooling Block
    Rad2 :TFC Xchanger Triple Radiator
    The Only change I'd make is a shelf for the pump with damping, lower the noise and allow for the tubes to the cpu and the tripple to be shorter and neater.
    And I should have got black tubes, but the silver over was left over from my last setup, I still had another 3 meters which I palmed off on mav-wil
    Anyway. the pics.
    One of the rad, seems really big
    One of the side open
    One closed, looks like a normal case, no obvious sign of the big WC setup.
    and my desk....
  7. Jipa
    5 Feb 2004
    No, I already took a close look at the Raven, this one is the Fortress 2. An even better case with the same frame but with an aluminum finish all around and a better HDD cage to boot. Gotta love it.
    AND PLEASE PEOPLE, RESIZE THE DAMN PICTURES! Nobody cares about 3000x2000 pix 3 MB pictures, resize those down to MAX 1000 pix and everyone will be happy.
  8. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
    Specs:
    Five 19" 16:10 monitors, only four are currently connected as my 8600 died.
    AMD 955 BE quad core processor
    Two 9600s
    3.5 TB of HDD space spread across 4 drives
    6GB of DDR3 ram
    The component video wire is connected to a 65" TV on the other side of the house
    You know, it is incredibly hard to find wallpapers (or images) that are 3150 x 2730
  9. dave_salmon
    dave_salmon What's a Dremel?
    24 Jun 2009
    Oh god this reminds me that i really need to dismantle my PC and actually put some thought in to cable management. I'll post some pics of my setup when I find my camera but the internals would make most of you cry I'd think so I'll spare you guys the pain and me the embarrassment.
  10. smc8788
    smc8788 Multimodder
    23 Apr 2009
    It's one of these.
    Like you said it's very similar to the P182, but a bit cheaper and slightly smaller (more 3.5" bays instead of 5.25" bays) with a black interior and single compartment design. It's really quiet and has good airflow, but the cable management could be a bit easier (there's not a great deal of room behind the MB tray for the cables, and the holes could be a little bigger as you need to remove the rubber grommets for the 24-pin power connector).
  11. Teelzebub
    27 Nov 2009
    my SLI rig Coolermaster 830 stacker / Hiper 880 psu / XFX 780i mobo / QX6850 @3.6g / TRUE cooler / 2x2 corsair dominator 1066 / 2x XFX 8800GT Alpha dogs gpu / samsung F1 750g / Vista ultimate 64
    Both rigs on the same 24in monitor
  12. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    i do have a p182 at home, but he just didn't got here yet.
    also, i route the cables to my screen like this, because it has to be easy to replace it, so i can sit on my bed for watching a movie.
  13. GingerFox
    GingerFox What's a Dremel?
    15 Nov 2009
    My pc
    The white wire dangling out goes to another cathode on the side of the case.
    Dell 20" monitor 17" relisys, Saitek cyborg, logitech vx nano...oh and my knakered chair lol.
    Can't see all of my desk either i shoved all the crap on the desk behind the monitors(Y)...really needs a tidy
  14. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    i failed hard at braiding, it was taking too long, i was sick of it so i left it unfinished :( . cables are slightly messy but they don't impede the airflow.
  15. dave_salmon
    24 Jun 2009
    Nice rig. I'm drawn to the rifle though. What is it? I have a .177 Diana Mod 32 springer with a Nico sterling Mount master and a generic silencer. I really need to use it more often.
  16. kenco_uk
    28 Nov 2003
    Inside my Coolermaster Cosmos. More.. function over form :)
  17. Teelzebub
    27 Nov 2009
    I've had that one for a few years now it's weihrauch HW 77k .22 with a hull cartridge muffler and a webley 4x32 scope quite a heavy gun , the window its leaning in looks over a field and the mountains so there good shooting from there.
  18. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
    Bit of a rush for mine so some a blurred. But yeah you get the idea, green.
    Enjoy.
    Flaming 9 I'll swap coolers with you plz :p awesome set up's everyone. Keep them coming.
  19. krazykid035
    13 May 2009
    I like how clean and tidy everything is and that chair looks super comfortable. Nice Rig.
  20. Zero_UK
    12 Aug 2008
    Cheers, Just dont want to see whats to the right of me :thumb: (and btw, GJ on that cable management!)
    Special chair shot.
    And yeah Im standing on my bed. My room is fricken tinny.
