Modding Pictures of Water Cooled SFF Build
Discussion in 'Modding' started by foz, 1 Sep 2009.
  1. foz
    foz hello
    4 Feb 2008
    I wanted to show some pictures of a case I've been working on for a while.
    Motherboard: Asus P5Q-EM
    Processor: Core 2 Duo E6600
    -Water block: D-TEK Fuzion
    Video Card: EVGA GTX 275
    -Water block: Koolance VID-NX275
    Memory: OCZ Reaper HPC Edition DDR2-1066 4 GB (2x2 GB)
    Power Supply: Corsair HX620W
    Hard Drives: WD Caviar Black 1 TB, WD VelociRaptor 150 GB
    Pump: Swiftech MCP350 with Alphacool top
    Radiator: Magicool Pro Slim Profile 2x120mm
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Nice build, just a little cramped. But good job.
  3. cronicash
    cronicash What's a Dremel?
    25 Aug 2009
    Flawless for what it is imo.
  4. jhanlon303
    7 Sep 2006
    Woot! Lian-li and well done besides. Most excellent.:clap::clap:
    john
  5. docodine
    docodine killed a guy once
    10 Feb 2007
  6. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    ive done one in the pc V300
    side pre paint
    took it out to digital overload. the lan held by CTRL+ALT+DEL
    entered it in the CPU modding contest they had out there and won. it ended up in the june issue of CPU LINK TO ARTICLE
  7. Avner
    Avner What's a Dremel?
    19 Sep 2003
    cool,
    nice integration, very clean !
  8. viking88
    viking88 What's a Dremel?
    4 Nov 2008
    VERY VERY nice.Love the green look through the small side panel window.Was that clear or acid green colour acrylic u used?
    And how you managed to fit a 2 x 120mm radiator into a case this small and tight fitting is way beyond my skills..I have one of these sff lian li cases and I found it next to impoaaible to fit in the PSU!
    Let alone a 2 x 120mm and fans on it! I salute your modding skill.
    Some more pictures would be nice to look through?
  9. Cheapskate
    13 May 2007
    Back to Foz- What is in the empty drive bays? -and how does the radiator get air?:eeek:
    I'd love to have a rig like that, but I can't get my hands in the full-size cases I built.
  10. Combatus
    16 Feb 2009
    Nice, I'd always wandered what the V350 was like for SFF watercooling. Looks like it's doable.
  11. foz
    foz hello
    4 Feb 2008
    The empty drive bays hide all the wires, although I could make room for another drive if necessary. The fans pull air through the radiator into the case through the front vents and bottom vents (not shown in pictures). It's not an ideal setup, blowing warm air onto the hardware, but most of the time I run it with the doors off anyways so it doesn't matter to me.
