Case Mod - In Progress PlayDoh Silverstone TJ 07 update 30.03.2014 with acrylic pipe
Discussion in 'Project Logs' started by arg-ist, 9 Feb 2014.
  1. Oozy
    Oozy What's a Dremel?
    11 Jul 2014
    I love how you created your midplate. I'd absolutely love to do that in one of my future build logs. May I ask you how much all of acrylic cost? How long did it take you for rendering the CNC-file?
  2. Oozy
    11 Jul 2014
    I absolutely love your midplate. Such a gteat idea.
    May I ask you how long did it take you to do all the CNC-stuff and how much did the acrylic cost?
  3. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Drawn at corel and converted to autocad for lasercut. It takes not more time than 1 hour to draw.
    For laser cutting 15 minutes .for laser and plexi. Paid 25 usd( ı live in Istanbul/Turkey !!
    Bonding in 2-3 days becouse ı make leak test for every layer.
    Today, it is an easy work for me, becouse ı did alot of them.
    Ilike to use midplates.and it is a must for Corsair 900D. for example:
  4. Oozy
    11 Jul 2014
    I just got back from Turkey. Holidays are over :(
    Does this midplate have a negative impact on water flow?
  5. Cheapskate
    13 May 2007
    You shouldn't have any flow problems with 2 pumps.
    -Looking good, by the way.:thumb:
  6. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    at worklog Playdoh Silverstone ,yes , becouse it has 2 pumps ..
    but at worklog SakSak case,I'm worried... becouse of 1 pump..
    but it can be used with 2pumps too.
