Motors Post your favourite detailing products, techniques and results
Discussion in 'General' started by Unicorn, 26 May 2010.
  1. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Any recommendations for a polisher that won't break the bank?
  2. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    i use THIS with good results...
    the ones i use a work are like £300-400 but give the same results
  3. Unicorn
    25 Jul 2006
    I have mentioned Larry and AMMO on bit-tech several times in the past couple of weeks, I'm also a huge fan and follower :thumb:
  4. Archtronics
    27 Jun 2006
    Ta very much will it be ok for a beginner?
  5. kirk46
    9 Jun 2012
    yes.....
    just make sure you do your home work,
    google rotary machine polishing techniques
    i did have a link but cant find it :(
  6. Hack'n'Slash
    Hack'n'Slash Minimodder
    20 Dec 2001
    You get faster results with a rotary like the one linked but dual-action polishers are usually recommended for novices or those at all nervous about the possibility of burning through their paint work. The Kestrel DAS Pro has been flavour of the month for a while and Detailing World are currently doing a Group Buy in conjunction with Clean Your Car, selling it for £99.95 delivered.
    Whichever you choose, as Kirk46 said, do your homework first with regards to technique, pads, products, ect, and if you can, grab a bonnet or wing from a scrapyard to have a bit of a practice on.
  7. Unicorn
    25 Jul 2006
    Larry Kosilla of AMMO NYC has said multiple times in his videos that detailing and in particular paint correction is more about technique and experience than the equipment or products used. Up to a certain point, he will be able to achieve better results with inferior pads on a cheap DA polisher than a novice with the best cutting pads on a top of the range Rupes polisher, because he's more experienced and has the technique to make whatever product is in his hands work best. The DAS Pro at £100 is silly cheap and is easily the best bang for buck machine polisher available for home users at the moment.
  8. Krikkit
    21 Jan 2003
    Ermagherd! Two new products tested for me this evening.
    First, Car Pro's Iron-X wheel cleaner. Repped to be pretty phenomenal, and justly so imo! My wheels were immensely stained from brake dust and road grime (lazy wash regime and minimal wax). Couple of snaps below show the difference after one application - this is just spray on, leave 5 mins, agitate with brush into the dirtiest bits, rinse. Nothing more.
    Before and after:
    [​IMG][​IMG]
    A lot of the lighter dirtyness would have come off with the usual sponge wash, but the brown/black deposits at the wheel roots were totally unshiftable. Now all the wheels look great (not perfect, but very decent).
    Second is Poorboys Natty Blue Paste Wax. I can't say I've ever used a proper paste wax before, I've only used liquids. Very easy to get on and off, the former simply being a damp microfibre and gentle wiping onto the panel. Pics tomorrow once it's been rained on, but so far the finish looks very nice. :)
  9. Archtronics
    27 Jun 2006
    Anyone recommend any deep scratch repair guides cars now clean but there are some pretty bad scratches.
  10. Krikkit
    21 Jan 2003
    Deep scratch, as in, down to undercoat? Through the lacquer?
  11. Archtronics
    27 Jun 2006
    There's a range some deep ones down to the undercoat and a couple of shallow ones to.
  12. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
    Here's a list of the products I use.
    Soap - Turtle wax 'Zip Wax' car wash & wax.
    Mag cleaner - DuPont Teflon wheel cleaner & Mothers Metal Polish.
    Leather care - ArmorAll leather care.
    Wax - Mothers California Gold carnauba cleaner wax.
  13. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Car =
    Bike =
    + WD40 & Paraffin
  14. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I do hope the fairy liquid is a joke.
  15. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Agreed. Total waste of fairy, use supermarket value/basics.
    I'm all out of stuff but I used to use an all in one wax shampoo on the old jaloppy. Now I'm in my vrs I need to get some products but being skint means it has to wait.
  16. mrlongbeard
    31 Jan 2010
    ok ok hands up, it's a generic representation of whatever the wife has in the kitchen, it's not always Fairy.:sigh:
  17. TheBlackSwordsMan
    16 Aug 2009
    Never use dish soap to wash a car, it will eat the wax like a piece of cake.
  18. Tim S
    Tim S OG
    8 Nov 2001
    I disagree...the only time to use it is if you want a completely blank canvas to work from. It's great for stripping away what products were applied in the past.
  19. Krikkit
    21 Jan 2003
    Hmmm, noted!
  20. mrlongbeard
    31 Jan 2010
    LOLs, you're assuming my car has been waxed, hell it's only been washed twice in the last 12 months
