Scratch Build – In Progress [project]6th GeN. 30TB - 2730W PSU ^^ Finale?!
Discussion in 'Project Logs' started by grevaeg, 22 Apr 2009.
  1. n0va
    n0va Burnin'!
    27 May 2009
    Germany
    Normally I'm not a fan of big cases, but this is just uber ****ing hardcore man. Awesome. Pure pr0n seeing that much hardware, clean and nice.
  2. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Australia
    congrats on the engagement and on an awesome build.
    wishing i had 30tb of storage lying around...
    wat sort of raid arrays have you got planned for all the drives? not many
    24+ port sata/sas cards i know of
  3. Sushi Warrior
    Sushi Warrior What's a Dremel?
    20 Mar 2009
    Well he does have 3 PC's inside that case :D
  4. dark_avenger
    9 Jul 2008
    Australia
    Link
    there you go 24 port sas/sata controller with it's own 1.2ghz dual-core processer and 512mb of DDR2 cache Cheesecake :D
  5. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    Mauritius
    ^^Oh my that is some serious cheesecake right there!
    :Edit: Both the case :jawdrop: :jawdrop: :jawdrop: and the 24 raid controller :jawdrop:
  6. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    near jase :P
    i love it
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Offenbach, Germany
    All you'll get at BT is cheesecake. :D
  8. grevaeg
    grevaeg Insanity driven
    17 Oct 2008
    I wont stop you :p
    And thx for the positive comments guys ^^ appreciated
  9. Nanosec
    Nanosec absit iniuria verbis
    28 Apr 2009
    Mostly Harmless
    Already done
    This has been done, but feel free to submit it again yourself, the direction on how to make submissions are right there on the front page
  10. Bad_cancer
    7 Apr 2009
    Mauritius
    *homer voice:* "Hmmmmmm, cheesecake...."
  11. Ministry Of Moddin
    Ministry Of Moddin What's a Dremel?
    1 Aug 2009
    Italy
  12. grevaeg
    17 Oct 2008
    Cable management, day 6
    Hi guys!
    Time for the long awaited update =)
    Whats been done
    * More cable management
    * Some hose management
    * Made a new holder to keep sata cables out of sight on the bottom module
    * Soldered power cables for the pumps and light's
    * Test booted all 3 PC's
    Well... as mentioned before, have been putting quite alot of time into cable management, its now officially day 6 of the management... and a decent 30 hours has allready gone into it 0.o
    God i hate this amount of cables... but hey... hopefully its gonna look decent when its done
    Also tried to hook up the screen earlier, works flawlessly =)
  13. DonT-FeaR
    23 Jul 2008
    near jase :P
    im so jealous
  14. perplekks45
    9 May 2004
    Offenbach, Germany
    ^ What he said.
  15. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    in a hole XD
    Thought of maybe using this as a rendering farm and offloading work over a built in lan?
    Andy
  16. Bear_2759
    Bear_2759 What's a Dremel?
    27 Apr 2009
    Sydney
    great work mate, just saw your last few weeks worth of work and it's progressing at a rate that is making me extremely jealous. I'm having trouble getting a welder to do mine that was put on hold 2 months ago... how are the HDD supports holding up now that they're fully loaded? are they showing any signs of stress?
    once again, great work.:rock::jawdrop::rock:
  17. grevaeg
    17 Oct 2008
    Have been putting a decent 6-7 hours a day on this project since the start of it =) so would be wierd if there werent any progress at all ^^
    (my ladie has been out of country for some weeks)
    The HDD supports are not showing any sign of stress at all, but only 12 disks in the top section atm, have more spots then disks atm ^^ 36 sata disks vs 48 spots, got 4 500gb ide's aswell... but wont be able to fit em in with this design along with the others... it just wouldnt look good.. I will get some supporting bar's between the two disk sections made.. to be sure it doesnt fail to stress later on
    Theoretically should the disk holders be able to hold around 100kg (25kg on each "foot") since its 6mm alu, did some stress test with a couple of pneumatic sylinders =)
    wierdly enough... i have enough space for now... so dont see the point in filling them up with new disks right yet
  18. Ministry Of Moddin
    1 Aug 2009
    Italy
    hi , GREAT WORK !!! i have a question for you : what kind of hdd controller do you use ?
  19. grevaeg
    17 Oct 2008
    Currently running 2x LSI 3041E-R RAID - SAS controller
    The rest is just onboard JBOD =)
    Got raid 5 support on mobo's 0.o
  20. grevaeg
    17 Oct 2008
