Scratch Build - In Progress ⭐ Project Alumina - A SFF Case
Discussion in 'Project Logs' started by shinji2k, 25 Feb 2018.
  1. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    There's been a bit of a set back. I got the case back a couple of days ago and I wasn't exactly happy with how it turned out. A friend of my boss gets a lot of things anodized so we just tossed it in with a batch of stuff he was already sending out. Well, it was anodized clear but it was such a thick layer it etched off all of my brush marks and discolored it a little. I ended up with a slightly pitted, green case. It was a freebie job so I can't be mad but now I have to get it looking good again and decided what plan B will be. I already spent some time getting it all removed with some bead blasting and did a quick test to see if I could get the same finish I had. I think it'll be ok.
  2. Cheapskate
    13 May 2007
    Ow. That seems to be a theme lately. "Got it back from X and it's f'd up."
  3. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    The case was looking great, hope your can get plan B working. You mentioned the 120W Pico didn't boot your computer, was the replacement a 150W pico or a different brand?
  4. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Yeah the 150W worked fine, the ones from mini-box. I haven't tried the 120W on anything else so I don't know if it was defective or if there was a timing or lack of power issue.
  5. CAF PCs
    CAF PCs Custom PCs
    11 Mar 2018
    $90 for the majority of a custom case isn't that bad I guess. Makes me sad thinking about the amount of aluminum milled out of the block turned into shavings
  6. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    KURT fixtures are the best. (bookmarked)
  7. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Yup Kurt is great as long as it isn't me buying it. Stupid expensive :grin:.
    Oh and I've been pretty busy at work, so not much progress going on. I was experimenting with a bead blast/clear cerakote finish and I think it will be acceptable. I was trying for a Macbook-esque finish and I think I can get close. I've kind of given up on the brush finish.
    Arboreal likes this.
  8. ccRicers
    ccRicers What's a Dremel?
    5 Oct 2017
    SFF - check. Alumimum - check.
    This is a very nice case! Even without the anodizing, the brushed finish looks nice.
    Glad it's for a Ryzen APU build as well. I have the same motherboard and cooler for one.
