Project: Black Metallic - LCD Paint Job
Discussion in 'Project Logs' started by Techx, 23 Oct 2006.
  1. Techx
    Techx What's a Dremel?
    9 May 2004
    This is my first paint project and actually took me several months to complete in my spare time. Someone at work gave me their 15" LCD, which has been sitting next to a window exposed to the sun for several years. Sun+Beige plastic^time=piss yellow... It was so ugly I had to take action... Here's what it looked like when I got it
    I wanted it to have a nice flat, semi reflective paint job and started to sand it down and throw primer on all of the pieces
    Then a lot of wet sanding.
    I decided on a a chrome/silver paint for the smaller peices
    I originally wanted black gloss, but after trying 2 cans of Duplicolor brand, the paint did not come out evenly or in a fine mist, but instead it spit out unevenly in blobs, no idea why this happened so I used a can of rustoleum metallic black which turned out nicely. Here it is after several clear coats and reassembled.
    I also tried several different cans of clear coat on the chrome but it always resulted in turning the chrome to grey, why this happened I don't know so I put another chrome layer and skipped clear coating it. There is some orange peel on them as well but I don't care, don't need to be that perfect for a 15" lcd :)
    heh, the 2405 dwarfs the 15"er
    I at least achieved what I wanted, to get a relatively smooth black semi-reflective surface.
    It's mostly done but I still want to change the power led, which turns orange when in standby and green when it's on, so I'm not sure what to do about that. Also want to install led's on the base as it has open "vents" which could create some nice lighting effects.
  2. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    110% better! Great paint job, looks fantastic. :thumb:
  3. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    way more than that! good job on that monitor, man, it looks really good. i suggest blue lighting for the grills, it will match your keyboard and mouse (and blue/black/silver is just bad ass)
  4. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    dude, looks stock :)
    Good work!
  5. DougEdey
    5 Jul 2005
    Looks brilliant, are you talking about the vents on the back?
  6. Techx
    9 May 2004
    Thanks :thumb: Yeah there are several openings on the back of the base..
  7. DougEdey
    5 Jul 2005
    I would personally put a low output LED behind the buttons, just to make em look nice. And the same with the base, I wouldn't put anything too bright because it may illuminate your ceiling.
  8. Jipa
    5 Feb 2004
    Gah that original color is TERRRRRRRIBLE. Looks like puke from the 70's. Really good job with the painting.
    Tho I guess you don't spend too much time watching the 15" when there's that nice Dell next to it ;o
  9. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Very nice,excellent!;)
