Looking very nice I think a white cooler would look great. Very "frosty" indeed. Never seen a white one before either so should be fairly unique.
Whoa painted heatsink ! I'd use white, it could look great in black case etc. What other HW you gonna use? Subscribed
Well I ll use Gigabyte MA790X-UD4 motherboard, AMD Athlon 5000+ X2, 4gb ram, HD 4670 and 2Tb hard drive + 640 gb hard drive. I buy some new parts but other hw is from my current pc so i dont need stronger pc for software and some game.
I use some color in spray... Heat will not cause problems, maybe few °C higher but nothing serious...
Case assmbled Today i assemble the case.. After successful assembling I decide to cut fan grill at plexiglass who will be the barrier betwen psu, hard drives and motherboard Everithing was good until i start sanding a and e letter. There everithing was going down :S The letters are broken and not longer in one piece.Tomorrow i ll try glue parts and save few hours of work.
After long time i have some updates Finally i paint and polish case panels. After fail with plexi logo i decide to cut out logo and put round mesh... Holes for watercooling tubes I use for power and reset switch. I pulled the cables and attached them to the back of mobo tray.
Work on case is almost done and its time to test electronics These are white leds On the plexy barrier i cut some other design. Tomorow i need sand angles a bit and thats done. Thanks to my colleague i have logo and i can start engraving it on side panel. And big thanks to my major sponsor, Fractal Design.
Today i receive my hardware for project AsRock 890gx Extreme 3, AMD Phenom II X4 945 3.0GHz, 4GB DDR3 GSkill Ripjaws Iam thinking about painting mosfet cooler in white... What do you mean? Thanks to my major sponsor
