Case Mod - In Progress Project -Cosmic Dust-
Discussion in 'Project Logs' started by Toru, 14 Dec 2015.
  1. Cheapskate
    13 May 2007
    Thanks. That's really clever.
  2. Toru
    Toru Minimodder
    14 Dec 2013
    I'm glad to hear you say that :D
  3. Toru
    Toru Minimodder
    14 Dec 2013
    Waterblock!  :D
    That was put on the market 14 years ago.
    AMD...mounting... :worried:
    G1/8
    Electroless nickel plating :thumb:
    O-ring
    LGA1151 Skylake mounting plate  :rock:
    polishing!
  4. Cheapskate
    13 May 2007
    OOh... That's awesome looking, I just hope the block can handle a newer chip.
  5. Toru
    Toru Minimodder
    14 Dec 2013
    Thanks Cheapskate :D The motion carried easily :thumb:
  6. Toru
    Toru Minimodder
    14 Dec 2013
  7. Vault-Tec
    30 Aug 2015
    Amazing. The paint is stellar too.
    Ed. And I love that CPU block too.
  8. Toru
    Toru Minimodder
    14 Dec 2013
    Thank you Vault! :thumb:
    I like old things :D
  9. Toru
    Toru Minimodder
    14 Dec 2013
    G1/8 to G1/4
    I plan on changing fitting. I'll test those depending on their arrival.
  10. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Great work man! That old CPU block looks pretty cool! I wonder if it performs well though? Excellent work on those fans!
  11. Cheapskate
    13 May 2007
    You guys look really angry.:D
  12. Attila
    Attila still thinking....
    22 Feb 2008
    That old block looks the bomb! :thumb:
    And I just looked up electroless nickel plating, a neat and simple process. Filed for future use.:naughty:
  13. Toru
    Toru Minimodder
    14 Dec 2013
    Thanks Bartacus! :) That leak testing finished with no problems :thumb: The fan is very visionary.
    hahaha :D They have a kind expression :cooldude:
    Thanks Attilia! :) Yeah, You should try this. :thumb: Water Cooled item of this era has a strong air of fancifulness. I really love that. Btw, I knew your worklog from before. Your job is also very amazing to me!
  14. Toru
    Toru Minimodder
    14 Dec 2013
    Project Completed!! :thumb:
    Thank you for watching!! :clap:
  15. hero1
    hero1 Minimodder
    18 Oct 2013
    Great work man. That painting trick really took me by surprise.
    The old style CPU block is a great touch and I wonder how long it will be before they reintroduce an improved version of it.
  16. Cown
    Cown Minimodder
    25 Feb 2012
    Nice looking build! Wonderful paintjob :thumb:
  17. Kviker
    Kviker What's a Dremel?
    22 Jan 2010
    Love that paintjob Toru! i have a question, what it is, like a spider web?
  18. Cheapskate
    13 May 2007
    @Hero1 - Probably never. It uses a ton of copper and relies on a precise fit on the tube, which means it's probably cast. Cast plexi tube is expensive.
  19. Toru
    Toru Minimodder
    14 Dec 2013
    Thanks hero1. This CPU block is a priceless antique :D Then it is a very weighty :cooldude:
    Thanks Cown. I like to challenge myself to new things :thumb:
    Thanks Kviker. It's a silk floss :rock:
    That's exactly how I feel also :thumb:
  20. Toru
    Toru Minimodder
    14 Dec 2013
    Cosmic Painting Tipss :D
    and green frake.
