Today is a good day! Finally arrived the newest Dremel cutting discs kit! so I can restart to work on side panels. Then arrived a new pack! Finally I've got my pieces that i've designed! Enjoy them... Now I must do only the curves on some parts, then I paint it and so I can build the final tower!
Here is some update... i did more space in the case... I did some cuts with Dremel on the inside panel, so it go inside better. However, during the folding, I earned 2 cm and so I cut the reservoirs panel too but the effect is not bad XD I'm finishing to assemble the base with the holes for the screws. Then i'll paint the inside in grey and glossy black!
Finally! I show you the assembled base! Really a pretty grueling ... in this heat then .. And then, with the case mounted on the base! Better that the render..No? PS (its height is 75 cm...)
I need you! Or better, I need an advice. Here is the left side panel render: Now the question is: I must do it in laser cut, so will be "flat" or in Black Glossy plexy using the CNC for a 3D effect? Also I'm working on wood for create the feets and the structure of fan grills!
I came back from summer vacation! Finally I can return to work! Now I've something of new for you! I'll show you one of most important parts of my MOD... Pepakura time! Where I'll put it for you?
This has an insane design! I, too, have been wanting to build a Star Wars themed casemod. I love the mass design integration from different aspects, i.e: The Death Star light panels, the octagonal windows from TIE fighters and the Emperor's Throne Room, now the pep mask?! Sweet! Do you have a link to the download for that mask?
Sorry man, I've lost the link for the Dath Vader mask... I found it googling. But this is my version... is different by the original file. However, stay tuned because more upgrades with new interesting Star Wars elements are coming!
To clarify a bit the ideas here some sketches of the result that I want to get As you see on the front will be two lightsabers... and these are the hafts!
