holy CRAP! what happened, a gas explosion, too many bug-bombs, spanish terrorists that really dont like your sister? im glad to hear she's all right. i dont understand spanish to that level (i had 2 years in high school), so im kindof in the dark about how it happened.
Thanks. Was a gas (propane? is the name?) explosion under the houses. Even her pet (a fat bunny) survived, luckily. I had to recover her HD's under a thick amount of dust
a fat bunny X-] sounded to funny good thing eweryones allright and dancnig or whatever.. peace out dudes and dudettes
Sorry by the delay, the promised explanation. Here some about the PSU fixing. I opened the PSU cover and located 3 or 4 points to make holes for the M3 screws (Be careful since screws shouldn't touch some parts). You have to line-up that holes with the ones on the perforated sheet, so measure several times. But if you take a simple pice of alu to make the fixing sheet, simply make holes in the both pieces at the same time, to be sure they'll match. I fixed the bolts/nuts with the PSU open and then close it. But if you want to mount it closed, you'll need to fix first the screws by a second nut (or fix washers, araldit or others...) if not the screw will turn. It's a simple way to fix the PSU without using the holes for a shuttle case.
