Scratch Build – In Progress Project: Large Wooden Tower - Finished!
Discussion in 'Project Logs' started by Spotswood, 19 Sep 2009.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Coming along nicely, almost finished.
  2. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    To help support the power supply I fabricated some posts made from a rubber bumper, 1/2-inch spacer and some nuts on a 6-32 socket cap screw:
    The hard drive cages are too tall to remove them from the case without having to first remove the entire lower shelf. To help ease that burden I devised a three-point mounting system whereby the cage is held tight to the bottom of the case via a center post and two socket cap screws.
    The hard drive cage's center support was drilled to have just a half a circle via a sacrificial piece of angle material:
    With that, the fabrication phase of this case build is done. :rock:
  3. Spotswood
    30 Jul 2007
    Last pics before stain and finish are applied:
    [​IMG] :rock:
  4. ringo
    ringo What's a Dremel?
    14 Jun 2008
    I like the compination of wood and aluminiium, that looks very good.
  5. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Is that the powerswitch at the back? Next to the PSU.
  6. Spotswood
    30 Jul 2007
    Yes, the power switch is on the back (as requested by the client), mounted alongside a hole for a 120mm intake fan. The mounting plate for the power supply is on the bottom. Both plates are the same size, so if one wanted to, their locations could be swapped. :thumb:
  7. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Ah, an intake at the back. :lol:
    It'd be nice if the client could get some pictures up when all the gears inside.
  8. Spotswood
    30 Jul 2007
    Here's a peek of the finish, which consists of two applications of a water-based black stain followed by two coats of wipe-on polyurethane. The two coats of polyurethane yields just enough shininess to match all shades of black computer hardware. :thumb:
    :rock:
  9. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Looks like ebony. Probably wishing that it was. ($150 per board feet)
  10. Spotswood
    30 Jul 2007
    The case is almost done. Enjoy.
    :rock:
    The_Beast likes this.
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I like it unstained, it looked like a cabinet
    BTW it's huge, and hugely cool
  12. Cheapskate
    13 May 2007
    I still don't like the black, but if it blends into the client's room like that, so be it. I think the black is a turn-off for me because of seeing lots of furniture ruined by teen-agers spray painting it black.
  13. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Not to sure on the black :(
    WTH?
  14. blt44
    blt44 Long Time Lurker
    23 Mar 2009
    Two-tone would've looked awesome. But hey, it's the client's call.
    Still super work though, man!
  15. Haynes
    Haynes Like the manual, just less useful
    4 Jan 2010
    Personally I like the black look over the original look (unfinished) with the aluminium it looks good :thumb:
  16. Spotswood
    30 Jul 2007
    Final pics!
  17. haakon.t
    haakon.t :)
    8 Dec 2007
    Looks awesome, well done! :)
  18. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Very nice indeed.
  19. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    This is a lovely wooden case that you have build. I especially like your attention to detail. This is evident in the way the wood grain is oriented in post #77. Simply beautiful man. I too liked the unstained look, but the client gets what the client wants. Overall it still looks awesome
  20. dryrice
    dryrice Zestious Knight
    8 Jan 2010
    a very nice case with good joinery. i am impressed!
