Cable routing, res change and M logo on GPU Okay, so after 14 days with 200 hours of work, i finally had the time to work on the beast again! I started doing the cable routing, and have done all the rest of the sleeving i needed to finish.. Still a long way to go with the cable routing tho, as i am awaiting new sata sleeving, hopefully be here monday ! I also finally got the last piece from parvum, that was originally going to be the SSD housing, but something went terribly wrong with the meassurements(prolly my side), so couldnt use it at all :/ So instead i took the Monster logo inlay in blue acrylic, and put in on top op the Gpu instead, left the black vinyl beneth to give it a "drop shadow" like effect And i made some changes to the reservoir sleeve, had to cut off some of the black binyl on the back, to give it the effect i was looking for. I took a picture of it so you can see what i mean.. Pretty sure when i am done with installing the lighting in the case, then it's going to look awesome!.. Anyways here's some images, while i work on installing the lighting, also i am awaiting new uv leds, to arrive monday as well, so final images will be done mid next week.. Same with the Sleeving and EK block polishing guide videoes Hope you like it so far, really in love with the LC Teleios sleeving!. looks so good in this build!.
Done Routing cables, Trying out blue Mesh So i just finished the cable routing ! im pretty happy with the result when you think of how little room there actually was for this, cause of the size of the AX1200i .. Also, i have been trying to figure out what to do for rad covers to be shown on the outside.. And i found some mesh laing around, spray painted it blue, and tried to put it loose on top of the rads.. Actually think it's lokking kindda cool, color matches okay too now to find a more permanent solution with it What do you think guys ? looks pretty good right ? Also still trying to figure out what do do with the PSU to make it blend in the black/blue theme.. Going to install lighting very soon, so i think next images will be final images !!!!! : D
!!!! - FINAL SHOTS - !!!! IT'S DONE !! The Parvum|Beast is finally finished... Sorry it took me so long to finish, but with 100 hour work weeks on my regular job, it got kindda hard to find the time to work on the Beast.. BUT time to share the final images with you guys.. I am very happy with this build, put a lot of attention to details into this one, and also a lot of blood and tears ! .. I will make the sleeving video, EK Frosted Block polishing video, and some other stuff tomorrow, and hopefully get it out to you guys before thursday.. Thanks for all of you who have followed this build, and a BIG BIG BIG Thanks to: Coolerkit.com - EKWB.com - Mainframecustom.com For their support and help making this build more than just a dream ! <3 .. Now THE IMAGES !! Again thanks for following this build guys, and thanks for the humongus support on my facebook page "BeckModZ - Liquid Designs" I can't believe that this build gave me over 2000 followers on my facebookpage .. THANKS GUYS!!! ..
It is a very nice build which you can be proud of. I love the design of the case and you made a very nice colour theme going. The only think I would have loved to see is the front face also being lit up somehow.
Thank you very much ! .. nice to get some feedback on it.. yeah i agree on the front face, i did try alot of things to make it light up more, but the 120mm rad blocks one of the eyes of the face, which made it very hard to light up. To start with i wanted to have the fan in front instead of the rad, but gave me some troubles with the reservoir positioning :/ I then thought about drilling a hole in the rad to make 2 x 3mm led's be positioned where the eyes are at, but would look a mess i think .. Still trying to figure out an alternative for it..
