Project Plex...
Discussion in 'Project Logs' started by axelh, 9 Apr 2007.
  1. KlavKalashj
    KlavKalashj What's a Dremel?
    7 Sep 2006
    Hardware? A mobo on that tray will look soooo good, I really hope it will be black PCB:)
    Anyways, really good work. Longing for next update.
  2. axelh
    axelh What's a Dremel?
    17 Dec 2006
    UPDATE 29.06.07
    After waiting a LONG time for some Bulgin switches, I finally received them.
    Now I am going to Denmark for a few weeks and I'll return with all the remaining parts for the case...
    Axel
  3. Teyber
    Teyber ******
    18 Mar 2007
    wow thats impressive
  4. THEkorean
    THEkorean 42
    10 Jun 2005
    i have to say i don't like all the CF especially cause its not the real stuff, but i have to applaud you for getting all that stuff on. You are amazing, i could barely apply the stuff on the front door of my wave master and here you did the entire inside of your case, that is truly amazing, keep up the good work :thumb:
  5. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Its impressive you got all this on, agreed, but theres just too much carbon for my liking, though as ever i will wait till the end to make my final verdict as things can easily change once everything is in!
  6. axelh
    17 Dec 2006
    UPDATE 22.07.07
    I brought the rest of the parts home from the holiday...
    Probably a couple of weeks until the next update because of work...
    Axel
  7. ssR
    ssR Carbon God
    11 Aug 2006
    Nice and clean so far, a bit overkill with the CF vinyl for my taste but i appreciate the effort, it came out flawlessly, at least in the pics :p
    This is looking good, keep it up!
  8. axelh
    17 Dec 2006
    thanks man... I guarantee that you will have a different opinion about the vinyl when the case is done...
    Axel
  9. axelh
    17 Dec 2006
    UPDATE 25.07.07
    Got a little bit extra time today so here is a little update...
    Recieved a package with:
    - Mist 600w
    - cables
    - 2x Samsung Spinpoint 500GB
    Don't have time to explain...sorry...
    Axel
  10. Teyber
    Teyber ******
    18 Mar 2007
    did you get enough a.c. ryan fans? lol jk, how many did you get tho!?!?
  11. axelh
    17 Dec 2006
    hehe...I got 5 80mm fans and 3 120mm fans...
    Update in a few minutes...
    Axel
  12. axelh
    17 Dec 2006
    UPDATE 04.08.07
    I built the machine and everything works perfectly! :D Here are a few pics...
    My idea for the case feet is pretty complicated. I'm going to have four layers of plexi where the plates will be 1cm wider downwards. The sizes will be 480*210*5mm on the top plate, then 230mm wide, then 250mm wide and the last one will be 270mm wide. There is also going to be a 1cm gap between all the plexi plates and uv light over the top plate. Anyways, you will see the result soon.
    I'm going to make the pieces to put between the plates now and I'm hoping for an update later tonight.
    Axel
  13. Teyber
    Teyber ******
    18 Mar 2007
    nice work!
    im hoping for some wa tercooling, that would really make a nice contrast with the carbon fiber!
    great work...
  14. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Great work man! Why no carbon fibre on the monitor?
  15. axelh
    17 Dec 2006
    Thanks man... Unfortunately I'm not going to use watercooling but I have some ideas with some watercooling tubing....
    Thansk man....I'm, not sure about the monitor yet..
    Axel
  16. axelh
    17 Dec 2006
    UPDATE 05.08.07
    I made the spacers between the plexi plates and tested it with uv lighting...Still needs some filing and I'm thinking about rounding the edges of the plexi...
    Axel
  17. The X
    The X What's a Dremel?
    30 Jul 2007
    Very very cool MOD !!!!!!
  18. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    ah, i love the look of the case feet. but i think you should take the top one off.
