Scratch Build – In Progress Project: Tachikoma - Wiimote Controller Test
Discussion in 'Project Logs' started by dimtec, 8 Jun 2007.
  1. dimtec
    dimtec What's a Dremel?
    15 Jun 2006
    Hi people!
    This is my second worklog. As the first one, I am preparing my mod for the Campus party mod contest, by the end of July in Valencia, Spain
    http://web7.campus-party.org/
    My project is called “Tachikoma” For those who are not familiar with the Anime “Ghost in the Shell” you could read:
    http://en.wikipedia.org/wiki/Tachikoma
    I have never made a theme mod. I was looking for something original, using fibreglass. First I thought of a Battlemech, but a walking mecha is very difficult and expensive to build. So I decided for the Tachi. I have been always a mecha fan since Robotech times.
    My plan is to use fiberglass for the case, and aluminum tube for the chassis.
    It would be radio controlled, with two electrical motors and car batteries to power them.
    First of all, I would need a 3D model of a Tachi. I thought of drawing it using some photos, but I realized that it would take too much. After a little Internet searching, I found a 4D Cinema model for 20 $
    http://planetpixelemporium.com/objectpages/tachikoma.html
    I imported into my CAD software and spited into several parts
    I had to rebuild the geometry with my CAD to have some functional and moldable parts. Draft angles are needed to assure that the part would pop out of the mold.
    My plan is to install the batteries in the head, and the hardware in the back cockpit
    To build the fiberglass parts, I have to build some plugs, which would be an exact copy of the final part.
    I made some 2D drawings with crossed sections for every part.
    I finished with about 200 sections.
    I plotted the sections and glued to cardboard.
    I build a skeleton for every part, with glue and nails.
    To fill the volume, I used 2 part polyurethane foam. It expands 30 times its volume. Little mess I made.
    After a lot of sanding and sanding, and filler and bondo (I think I am in the 7th layer)
    Connector between the head and the cockpit
    The two parts for the cockpit
    To realize the dimension of the model -50 cm ruler
    Elbow
    Eye
    Arm
    Front Cannion
    Upper head
    Lower head
    One or two layers more are need to finish.
    This is for the moment. My plan is to finish the plug this weekend, and start with the fiber glassing next week.
  2. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Now THIS should really be fun to watch take shape...
  3. MrWizard6600
    MrWizard6600 What's a Dremel?
    20 Jun 2006
    Tachikoma!
    I cant wait to see the final product, keep up the awsome work bro.
  4. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    one word.....................................WOW!!!!!!!!!!!!!!
    :thumb:
  5. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    yup...wooow!
    This will be cool to watch!
  6. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Very nice start! Subscribed!
    edit: are the pictures from 2003? :eeek:
  7. dimtec
    15 Jun 2006
    No, are for last week. I forgot to change the date of the camera last time I ran out of batteries.
    I started with it in December last year, but It passed 3 moths with out any advance, because lot of work.
    Now I am working very hard to have it finished in time.
  8. jegerjon
    10 Jan 2007
    Ah okay i see, but it's really good looking, keep it up ;)
  9. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Can I just ask something quickly, will this be your computer case? With all your computer equipment indside? And it will be able to walk???
    (Sorry about this - but its so unconventional - whicvh is GREAT!! - i am a bit lost)
  10. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    hey your mod looks great and it loks like you have really thought out your design
    so i hope it all goes well for you
  11. wbdog206
    wbdog206 not me
    15 Jan 2007
    i will be keeping an eye on this project.
    looks very interesting.
  12. elliod
    elliod What's a Dremel?
    1 Oct 2006
    WOW really an amazing and original project cant wait to see more of this.
  13. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Man you must be crazy, this will be great! Sure will follow this thread : )
  14. widmod
    widmod Minimodder
    9 Oct 2006
    nice idea and jea I'm glad about your crazyness too :worried:
  15. devilhacker
    devilhacker What's a Dremel?
    15 Feb 2007
    very nice!!! I like Ghost in the shell mmmmmmm....
  16. pedrofilho
    pedrofilho What's a Dremel?
    4 Apr 2007
    Very nice work buddy. Liked the materials you used to make the models.
    Keep going.
    Pedro Torres.
  17. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    I brought this last year
    I think it looks like the pod on the rear.
    Mond ON !!
  18. Guest-16
    Guest-16 Guest
    Wow! Keep it up! /subscribed
  19. dimtec
    15 Jun 2006
    First of all, I want to apologize for so long time without updating my work log.
    I could not progress in my work until a little ago. Basically I had some problems with my neighbors.
    I was working on a storage room on a common basement of the building.
    You know, the sanding process generates a lot of dust, and I was covering with dust everything. So because I am a good neighbor, I decided to move to another place.
    I have been looking for a place to work for 3 weeks.
    At the end, a friend let me a place. It was a non used industrial building. I have a lot of space, and no one to disturb;
    This is a photo of the new place:
    A week ago I restarted the works.
    I have been working on the plugs, sanding and repairing the surfaces.
    I have glued the plugs to a MDF table as a flange.
    I have done my first mold. This is a trial to see if it works. I have used plaster, and apart of some minor Faults, it’s okay.
    I decided to use plaster because there are some bumps in the plugs, and I would fix then in the plaster molds
    This is what I use for mold reinforcement. They are cotton yarn.
    I have covered the entire plug, after waxing it, with a 2 cm layer of plaster. When it started to cure, I cover with another layer of plaster with the cotton.
    This is a special wax for molds I have used. It works really great, the mold popped out of the plug very easily.
    More soon
  20. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    dude it looks awesome already. yeah you have put alot of thought into this. great skills and all the shabang!
    keep it up.
    SUBSCRIBED!
