Case Mod - In Progress Project Thief -Completed 11-2014 -2 CPUs,8 GPUs,4 Loops,6 Pumps,50 Fans,2TB SSD
Discussion in 'Project Logs' started by stren, 20 Dec 2011.
  1. stren
    stren What's a Dremel?
    9 Dec 2011
    Haha so true, if you stop getting updates, it must have learned to exterminate!
    haha thanks yeah it's a beast!
    Well 5.2 was just for benching, the temps were actually fine (70s), but it wasn't stable for 24/7 nor were the volts friendly for 24/7. For now I'm running 4.9GHz 24/7 and folding bigadv I get temps in the 59-69C range across all cores with a 25C ambient.
    Thanks don't worry it'll fill up, just will take some time :)
    Thanks for the feedback it helps :)
  2. stren
    9 Dec 2011
    Took a break to put together an ivy rig for a co-worker:
    A board!
    blah blah blah marketing - where's the window that the extreme boards have?
    Now there's a board
    I liked the door hanger - unfortunately this is for an overclocked workstation so not too useful here:
    A large box for some memory (32giggles):
    Matching:
    Oh and a cpu:
    Best put that in the socket then:
    We should remove that plastic cover too:
    Putting in that H100:
    Yeah I know no custom water loop, but this is going to someone who can't be trusted with such things ;)
    miniThief is getting there:
    miniThief- now with 100% more PSU:
    Don't forget a GPU (9800GT Cheesecake!)
    Close up:
    ISO:
  3. stren
    9 Dec 2011
    Also made an unboxing video of the mobo/cpu/ram:
  4. stren
    9 Dec 2011
    So back to the *real* project. Now that my workstation was up and running, I could take the old one down:
    OMG dust! This is three months worth:
    Still yucky:
    Got out the duster and started taking it apart:
    Nearly done
    Now I've gone and made the kitchen messy again:
  5. stren
    9 Dec 2011
    So as it's the weekend you get bonus updates :)
    This is how I initially wanted the PSU's to give maximum air intake:
    However the left PSU once it had cables would conflict with the 360 rad mounted in front of it, so I decided to move it:
    Done, you can see there's still a good amount of space in between:
    Now to mount them - they're going in the second to bottom compartment:
    and mounted:
    Now time to mount all the hard drives - here are the gaming rig drives:
    Now let's add in the workstation drives:
    old skool x25e:
    All done:
    Now to cable it - I hate how asus only give you sata cables with right angles at one end and straights at the other. For this build I really need straight to straights, so I had to order some more from the egg, this is the temporary rats nest:
    Yikes!
  6. KidMod-Southpaw
    28 Sep 2010
    Your insanity pleases me.
    Love this! :thumb:
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Haha, even in a case this big you run into space problems. Hilarious. :D
  8. stren
    9 Dec 2011
    Lol thanks :)
    Haha too true!
  9. stren
    9 Dec 2011
    Alright a quick update as I got some more time to process photos (on a side note the first mdpc package came woot!)
    I got the workstation back up and running:
    But I had to use the gaming side for location of the power supply as the cables were not long enough to reach the real location. As you can see it makes a good storage room also:
    Workstation in action - no 2nd 8800gt yet because I'm only driving two screens, the card is being used as a test card for now for some other rigs I'm building.
    Again a lot of fittings are temporary. So now back to the gaming rig. I transferred the sweet trident ram from my worksation to the gaming rig (I think it maybe hypers), it can do 2130 CL 8 and probably more but that's the limit of my 990x IMC. Should have tried two sticks in the 3770K rig I slapped together to see what it could really do! The ugly p6t board that was being used for the workstation is now going into a generic network maintenance use and will be put in a rack.
    A shot of that sexy ram:
    And the motherboard tray:
    Here you can see I had soldered on an extra molex connector to the board (just to the bottom of the STX). My old case didn't have room to connect a power cable to the real connector, so this helped me give the gpus enough power.
    And now time to swap the 920 for that sweet 990x:
  10. whyte
    whyte What's a Dremel?
    27 Mar 2012
    must try.. and contain.. jealousy....
  11. KidMod-Southpaw
    28 Sep 2010
  12. stren
    9 Dec 2011
    Lol thanks
  13. stren
    9 Dec 2011
    Alright time to swap those cpus - out with the 920:
    And in with the 990x:
    Close it up:
    Mount the CPU block and add the g3/8 adapters - luckily the 5Noz has a very wide port spacing:
    Which means you can mount the high flow VL4N quick disconnects - unfortunately they are g 3/8 and don't come with right angle options, so I have to have adapters both ends and then a g1/4 female to female before I can add in the 90 degree rotary fitting:
    Here we are with the old GPUs mounted too:
    And here's how it will look as this will be the reverse ATX side:
    Now it's time to repurpose that clown board:
    And done til the case comes:
  14. stren
    9 Dec 2011
    Second update of the day - sleeving came in:
    Always interesting to see stamps from a foreign land ;) And of course the obligatory nils drawing
    The results from the last survery were clear:
    So now I made them with real sleeve (24 pin left and 8 + 6 pin right) (only one row of course) (photographed outside under cloud, the background is the pedestal back plate which is powdercoated the same color as all internal parts):
    I'm leaning towards D or F. However there's one last complication there is red or the "x" color that is basically a deep red-brown kind of color. As far as I can tell, the x looks better when next to white, the red otherwise:
    Let me know what you think!
  15. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    I really like A and G the most! That sleeving really looks good :)
  16. Big Elf
    23 Apr 2009
    I prefer 'B' although I'd probably use a maximum of 3 colours. Have you tried sleeving the red onto a white cable? It tends to brighten it up a bit.
  17. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    A and G are my favorites.
  18. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    the last one with color x!
  19. n1c3tr1
    n1c3tr1 What's a Dremel?
    4 Jan 2012
    Option D with Red.
    Also keep the updates coming!!! I check almost everyday to see how much progress you have made.
    I guess I will have to find something else to do with my time when you complete it...
  20. stren
    9 Dec 2011
    Thanks everyone - keep those votes coming - here are the results so far:
