Case Mod - Complete Project Virus -Hydra desk case- (Finished)
Discussion in 'Project Logs' started by Y.G Casemod, 8 Mar 2017.
  1. Jezzafool
    Jezzafool What's a Dremel?
    2 Sep 2011
    That lighting looks great :thumb:
  2. Y.G Casemod
    Y.G Casemod Extreme modder
    8 Feb 2017
    In these photos, we will see the 250mm Frozen Q LF Reaction tanks for the aesthetic loops.
    The two pans will be placed in the desk legs and the liquid pipes will pass under the desk top.
    Remember the two flat pans?
    Well, the two systems are separate and will also pass through the flat pans on the front of the desk.
    Stay tuned.
  3. Y.G Casemod
    8 Feb 2017
    THX.:thumb:
  4. Y.G Casemod
    8 Feb 2017
    Mounting aesthetic loops in the legs of the desk.
    Stay tuned.
  5. Y.G Casemod
    8 Feb 2017
  6. Y.G Casemod
    8 Feb 2017
    He begins to take shape.
  7. Y.G Casemod
    8 Feb 2017
    Internal grid 360 mm DX side and internal grid 480 mm SX side.
    Also made biohazard logos.
    All in metal, painted and hand aibrushed.
    The logos will be applied to the metal meshes mounted on the grid frame.
    Stay tuned.
  8. Y.G Casemod
    8 Feb 2017
    Other pieces are built .....
    In these photos the DX backlit bulkheads (in the first published photos, if you remember you see rough)
    In particular, you can see the backlit armor to the motherboard with a complete positioning test on the desk's mb tray.
    There is still much to see.
    Stay tuned.
  9. Y.G Casemod
    8 Feb 2017
    Some saint starts to pull down with the cabling ....
    Stay tuned.
  10. Y.G Casemod
    8 Feb 2017
    Assembling and wiring of the 6 Poweradjust modules of Aquacomputer.
    All mounted on the bay 5.25 (x2) bay.
    4 of the 6 modules are used to control the pumps, the remaining two for the rad fans.
    Respectively 4 fans on rad from 480 for the cpu loop and 9 fans on the 3 rad 360 loop gpu.
    All this requires programming of each PA using Aquasuite software.
    Stay tuned.
  11. Y.G Casemod
    8 Feb 2017
    It goes on ......
    In these photos we will see:
    Mounting and connection of the 360mm radiators with tubes and fittings in the DX leg of the desk.
    Mounting and testing of the 9 TB Vegas fans of Enermax.
    These 3 rad will be for the GPU loop.
    Stay tuned.
  12. Y.G Casemod
    8 Feb 2017
    Let's get back here.
    In these photos we will see the preparation and final assembly of the motherboard with its WB to the processor fittings and everything.
    In the details you can see the mounting of a probe on the WB to monitor its specific temperature.
    Stay tuned.
  13. Y.G Casemod
    8 Feb 2017
    Meanwhile, we manufacture other pieces .......
    Stay tuned.
  14. Y.G Casemod
    8 Feb 2017
    The installation of the cooling system ......
    Stay tuned.
  15. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I shall name you... Sir Bling-A-Lot!
  16. Y.G Casemod
    8 Feb 2017
    Top.:thumb:
  17. Y.G Casemod
    8 Feb 2017
    Forward.
    Installation phases of intake fans and internal grille on DX side.
    Follows the mounted backlit illuminated panel.
    In the photos you see the housing bar for UV lights that will illuminate the grid by highlighting the fluorescent paint of the aerography.
    Stay tuned.
  18. twister7800gtx
    twister7800gtx Minimodder
    2 Nov 2011
    Great work mate :rock:
  19. Y.G Casemod
    8 Feb 2017
    THX bro.:rock::rock::rock:
  20. Y.G Casemod
    8 Feb 2017
    Last part of the worklog before the photos and the final video.
    Video cards.
    On board in this build there are 2 Titan X.
    In the photos we will see the unboxing, the manufacture of backplates customized, airbrushed and backlit, and mounting cards with the WB ready for the liquid on the MB.
    Finally, if you like, take a look at this short video intro, which I created to create a story about mod.
    Below the link to the intro.
    Stay tuned.
