Scratch Build – In Progress Project : Zotac ITX Rebox -12th Feb - Completed - MOTM nominee
Discussion in 'Project Logs' started by bugeye, 8 Nov 2011.
  1. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Love the visible white edge. It makes the case look smaller having a light border around the dark faces.
  2. Liighthead
    Liighthead What's a Dremel?
    26 Nov 2011
    the cnc guys you were talking about are epic pc cases
    if that helps :)
    haha yeah i see what you mean about the knowing enough to get u into trouble :p
    im almost in the same boat
  3. bugeye
    bugeye Sleep Deprived
    16 Aug 2011
    I think you are right .... I knew it was something just not quite what :)
    That's the one , very neat case I think :)
  4. bugeye
    16 Aug 2011
    Mini update :)
    I've been working on fine tuning the bending of the internal part of the case . I'm trying to improve the accuracy of the tabs etc .
    So yet another template , turned through 90 degrees so that the coloured panel is on the front . I've also put in the mounting points for the standoffs etc
    A slight change to the strip heater ... these bits hold the wire in position more accurately .
    Almost there with the corners :)
  5. jrs77
    jrs77 Modder
    17 Feb 2006
    Awesome bending there :rock:
  6. Liighthead
    26 Nov 2011
    very nice :)
    also simple but nice idea with the alu. to keep ur heater in place :)
  7. bugeye
    16 Aug 2011
    Thanks :) it's getting there :dremel:
    So after many templates , jigs and remakes of templates and jigs and trial pieces and slightly different trial pieces ......
    I finally feel like I'm getting this sorted :lol:
    The internal and front and back bits for two cases .... both the same size ( the right size ) , both square and they match each other :)
    So next to sort out is the cut out for the I/O plate then on to the cover and some sort of ventilation .
  8. bugeye
    16 Aug 2011
    Last thing for today .... cut out for the I/O plate .
  9. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Too bad your not in the US. I'd deff pay for one of those little cases!
  10. bugeye
    16 Aug 2011
    Thanks Fuganater :)
    I checked earlier in the thread and I think it's about £15 to ship to the US :naughty:
  11. Knighthammer
    Knighthammer What's a Dremel?
    18 Feb 2011
    Great looking little case.
    So I'm assuming the power would come from a mini-psu or what did you have in mind?
  12. KidMod-Southpaw
    28 Sep 2010
    How much would one of these be to buy? They look great and I'm definitely interested in one of the little guys!
  13. wejjy
    wejjy Minimodder
    9 Aug 2010
    I love this, its the absolute opposite of my build but im intrigued and its making me like the idea of a miniature PC more the more I see. I could replace my slow Nas box with one. Im subbed!
  14. bugeye
    16 Aug 2011
    :) yep a pico psu or a motherboard with onboard power .
    :) I'm not 100% sure on costs yet , when I've worked out the size of the cover etc I can get prices from the laser cutters . The whole thing really comes down to that cost .
    Thanks wejjy :) NAS box ..... hhhmmm thats and idea .
  15. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    This looks awsome, I would be interested in one for sure
    post the prices when you have worked things out, possibly a replacment for my acryan box,
  16. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    That is an awesome work, bending master skillz :thumb:
  17. bugeye
    16 Aug 2011
    Hope to have things sorted out early in the new year :)
    Thanks GuilleAcoustic it's been an interesting thing to learn .... quite a big difference between just bending a bit of acrylic and getting the bend in exactly the right place with the right angle . The strip heater really does make a massive difference so thanks again for your link back on page 1 :)
  18. bugeye
    16 Aug 2011
    Well I've been working on the cover today . I've got the main part of it sorted out .
    I can get a fit that I'm happy with cutting it on the table saw . I'm hopeful that it will be ok with the laser cut ones as it needs to be pretty accurate to get a good fit .
    Just the ventilation to work out now and I can send drawings of to the laser cutters :)
  19. Knighthammer
    18 Feb 2011
    Look'n good!
  20. Mojo
    Mojo Multimodder
    18 Nov 2011
    i'd be interested in buying one also :)
