Case Mod - In Progress Purpura (XPS 720) Completed !!!
Discussion in 'Project Logs' started by alain-s, 5 Jan 2014.
  1. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    HELL YES!!!! :rock: :rock: :jawdrop: :jawdrop: If (when) I do hard tube, THAT is what I want! Dat chrome bling, yo. :D Amazing work Alain!!! :clap: :clap: :clap:
  2. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Just got to stay absolute beautiful.
  3. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    What an absolutely stunning mod! You always amaze me!
  4. charles_h
    charles_h I can has RotoZip?
    14 May 2008
    Simply magnificent, Alain! Bravo! :clap:
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    Forgot to state you brought beige back in kickass fassion. :D
  6. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank you Icelander :)
    Thanks Attila :p I need to say that the pictures with the lights turned out pretty great.
    Thx Dot_Kappa ^^
    Thanks Tim :D
    Thank you Waynio ^^
    Thx HackJoe :D
    Thank you Bulldogjeff, glad that you like the beige to. :rock:
    Thank you Bartacus :D
    Thanks Kovoet :)
    Thx Ianovski :D
    Thank you Charles :)
    Yes idd it something else then black and white cases :)
  7. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    I've come back to this thread 4 times to gawk at those pics. :D
  8. alain-s
    alain-s Minimodder
    12 Jan 2011
    Lol
    I you want I can send you a link with full res pictures. :p
  9. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Yes please. I'm getting drunk and need fap material. :D
  10. Cheapskate
    13 May 2007
    Friggen beautiful, man! Not many can rock the beige with the class this pulls off. I would have loved to seen what would happen if you painted the underside of the inner panels, THEN got them laser cut. They work really well in the satin finish here, though. -Just so many nice details... The discreet start point of the EL wire, the exposed metal on the edges... -BTW, how did you do that without staining the paint with the dreaded black polish grime?
  11. alain-s
    alain-s Minimodder
    12 Jan 2011
    Lol wel enjoy I would say.
    http://1drv.ms/1faUkPz
    Thank you Cheapskate,
    Sanded the edges of the panels to grid 2000. Then I used Commandant nr5 to get the finish. I could have gone higher to 3k but I didn't had any sanding path with me.
  12. alain-s
    alain-s Minimodder
    12 Jan 2011
    No modding update or anything just a little something new.
    I am proud to announce that my website Simplicity Designs is online!
    http://www.simplicitydesigns.biz/
    Go check it out and spread the word!
  13. Dimbidim
    Dimbidim What's a Dremel?
    19 Jun 2014
    I love this build. One of my favorite since the beginning of the year.
    Question:
    Was the creamy white of the outside intended to contrast with the regular white of the inside or was it a paint job issue which turned out good?
    I'm asking this because I had regular whites turning creamy because of UV exposure before clear-coating.
  14. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank you Dimdibim,
    The creamy beige look on the out side was intended. My first Idea was to paint everything white.
    But after some time I wanted a little bit of contrast with the inside.
  15. Sanjaya
    Sanjaya Minimodder
    4 Sep 2013
    This is insane!!! epic build
