Just a quickie, I hope. I'm making a little website for a friends band from Argentina, and have made a quick, basic php script which allows them to post stuff on a news page from a html form. Here's the php script for entering into the database: Code: <?php $title = $_POST["title"]; $text = $_POST["text"]; $connection = mysql_connect("localhost","username","password") or die ("Couldn't connect to database server."); $db = mysql_select_db("dbname" , $connection) or die("Couldn't select database."); $sql = "insert into psychotoxic values ('$title', '$text')"; $sql_result = mysql_query($sql,$connection) or die("Couldn't execute query"); mysql_close($connection); print "Information Accepted." ?> This works completely fine, not a problem. I have also made a script to extract 5 entries from the database, and place them in a html table: Code: <?php include("logo.htm"); $connection = mysql_connect("localhost","usernamei","password") or die ("Couldn't connect to database server."); $db = mysql_select_db("dbname" , $connection) or die("Couldn't select database."); $sql = 'SELECT `title` , `text` '; $sql .= 'FROM `psychotoxic` '; $sql .= 'WHERE 1 LIMIT 0, 5'; $sql_result = mysql_query($sql,$connection) or die("Couldn't execute query"); echo "<br><br><table border=0 table width=700>"; while ($myrow = mysql_fetch_array($sql_result)) { $title = $myrow["title"]; $text = $myrow["text"]; echo " <tr> <th> <strong>$title</strong></th> <tr><td><h1> $text </h1></td> </tr> "; } echo "</TABLE>"; mysql_free_result($sql_result); mysql_close($connection); ?> This also works great, but I need it to extract the 5 newest entries rather than the 5 entries that were first entered into the database. I also need it to put the newest entry first, then going down the list as the entries get older. I apologise for my English, bit tired at the moment If anyone could help me with figure out what I need to do, I'll greatly appreciate any comments/suggestions.
Give the table an ID column or if there already is one then: select ID as well as title and text then order by ID descending: SELECT id,title,text FROM psychotoxic ORDER by id DESC LIMIT 0,5
