Scratch Build – In Progress RÛNÎK by DJB (Finished)
Discussion in 'Project Logs' started by Diegojavbau, 13 Jul 2011.
  1. Diegojavbau
    Diegojavbau What's a Dremel?
    13 Jul 2011
    Hi , this my first post here , I´m glad of be part of the comunity. :thumb:
    RÛNÎK is my last work , is a thematic mod made for an ecological modding competition , so was build using only paper and cardboard
    It represent an ancient object that belong to an old runic culture made of stone , but at the same time has a ultra-modern technology inside , so it is being investigated , I´m a big fan of Tomb Raider and Indiana Jones :D
    In a couple of my projects , I introduce the concept of 2-steps turn-on , here you can see an effect after turn on the PSU (the cpu is still OFF) and the status change after turn on the PC.
    When the CPU is ON, a "Power Circle" of runes of light is projected at the front of the PC , this is inspired in Warcraft game :naughty:
    Gallery
    There is more pictures that I can´t show because has the competition organizer logo and can be see as spam , you can find it in my Blog
  2. Diegojavbau
    13 Jul 2011
    Worklog
    I start with a prototype just to try some designs , result:
    Generally , people think that an cardboard mod must start with a box , I think different , then I decide to choose other way to use this material
    I made a lot of structural square columns to build the chasis
    Building the chasis
    Almost done
  3. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    Looks very cool. I love the projection given off!
    Not entirely sure about the Blue LEDs. Bit too much of a contrast with the yellow.
  4. Cheapskate
    13 May 2007
    Excellent use of cardboard!:thumb: The rune projection is d*mn clever.
  5. Diegojavbau
    13 Jul 2011
    Thx for the comments ; I´m glad you like it !!!
    More worklog
    Front panel , roof and inner floor build
    Hdd rack
    Front panel ligth show
    Make a transparency effect ussing paper was a real challenge and a lot of work.
    First , the runes was made at hand one by one in a black cardboard sheet.
    A big led panel was made and put behind the runes
    And a PCB for the oscillator
    Test
    Card mothertray and back panel
    Artistic shot :naughty:
    Painting and stone effect cover + side panels
    Lower front panel that contains the projector and the main buttons and the optical drive
    Projector
    Projector support made of cardboard (i think I write cardboard a thousand of times :duh:)
    A dc motor and a 1w led was used in the projector
    Testing
    Finally , for the CPU cooler radioactive logo , I use a strobe ring of UV leds that I develop earlier for my first mod OBSIDIANA , that I will post later.
    The frequency of the oscillator is variable and that allow different visual effects
    Here a video , so you can see how it works
    PD: I hope not bored you with the long worklog , thanks for reading.
