Scratch Build – In Progress Raspberry Pi Competition - The 'Golden' Wet Pi. *Finished with final Pictures*
Discussion in 'Project Logs' started by Phame, 19 Feb 2013.
Coolant colour?
  1. Blue
    10.9%
  2. Green
    6.9%
  3. Yellow
    5.0%
  4. Pink (Raspberry Colour)
    60.4%
  5. Red
    16.8%
  6. Purple
    6.9%
Multiple votes are allowed.
  1. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    overkill? never heard of it... :D
    well next thing is singlestage from office watercooler compressor :)
  2. arakis
    arakis What's a Dremel?
    24 Aug 2011
    Just to note that the actual water block will be cooling RAM and not the CPU.. R-Pi uses a sandwiched CPU RAM design... PCB|8|CPU|8|RAM|watter block.. -8s represent Ball grid array..
    Anyway, great design, can't wait to see this beast :)
  3. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Thanks dude for your kind words, can't see myself winning it as there as some great cases being done. It will get finished :D I have till April so its an easy deadline to meet. I cut the stainless for the case last night and started doing cutter paths for the CNC.
    I know it probably sounds stupid watercooling it but why not eh! :D
    :D
    siliconfanatic likes this.
  4. Boorach
    Boorach Minimodder
    16 Feb 2013
    The answer to "why" is always "because I can".
    Really look forward to following your progress.
  5. Baguette
    Baguette What's a Dremel?
    6 Aug 2010
    Wow. Speak of going all the way huh... XD Gonna look sweet :p
    Be carefull when overclocking ARM processors though, it isn't just a question of managing heat, high overclocks age the processor really fast. Just a thought :)
  6. faxiij
    faxiij Minimodder
    25 Jan 2011
    Not stupid - but mad. And madness is awesome. Just think about 300. SPARTA! Cheesecake.
    Madness just wins, every time. These wicked times we live in just support that fact even more.
    In fact, I'm just waiting for people to wc all kinds of CE stuff. Like their tooth-brush (steam-punk style!), monitor or HD-projector. The less sense it makes, the better it is! :D:hehe::dremel:
  7. panman9
    panman9 What's a Dremel?
    9 Dec 2010
    Haha man this is awesome! Awaiting updates
  8. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    No kill like overkill :)
    Sub'd
  9. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    very nice idea, all looks great am just missing the handwork, too much cnc and co.
    thats a pity. otherwise its perfectly perfect,,, if you know what i mean.
  10. faxiij
    faxiij Minimodder
    25 Jan 2011
    can we haz moar updates? :eyebrow::lol:
  11. KidMod-Southpaw
    28 Sep 2010
    Agreed, I'm desperate to see some real life overkilll! :D
  12. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    You're going to have to add fillets to the leafs on the raspberry or the CNC won't be able to cut those sharp corners.
  13. Cheapskate
    13 May 2007
    @Achron - I wasn't going to say anything. It's possible on something this overkill that he's laser etching the surface 60,000 times to make the relief.:lol:
  14. Phame
    17 Sep 2012
    The general shape is not going to be a boss its self, I have modified it to be more of a domed boss that why I can get a nice small ballnose to etch the shape instead of an endmill simply leaving material on.
    The machine is cutting the waterblock as I type, I have just g0t back from holiday hence no update.. I am now back at work and will show you the micro waterblock.. :D
  15. Phame
    17 Sep 2012
    As promised earlier.. Here's an update..
    This was ruffed out with a 2.0mm Endmill and finished with a 1.0mm Endmill.
    I am currently waiting on a 0.5mm Endmill to clean out channel out.
    With the holes, drilled at 1.2mm for a M1.6 caphead screw.
    I will continue to cut the underside of the waterblock tonight and have an update for you later.
    This was just a tastier so you didn't give up on the idea of it! :thumb:
    Thanks guys!:dremel:
    dark_avenger likes this.
  16. faxiij
    faxiij Minimodder
    25 Jan 2011
    yeeeeesssssssssssssssssssss.
  17. Phame
    17 Sep 2012
    Thanks Fax :D
  18. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    My eyes just exploded:eeek:. Just too much overkill awesomeness going on here :D
  19. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    with rads? pump? submersible? in a size constraints of 6" square?
  20. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    I think the idea was for one of the sides of the case being the radiator. Kinda like an old school cpu radiator with a thicker base and water channels in it. This will be mostly the same as using a heat pipe to a solid radiator than how "normal" water cooling systems work.
