Case Mod - Complete Raz3r D3sk - Finished! - Final video online
Discussion in 'Project Logs' started by l3p, 21 Sep 2013.
  1. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    Seriously love the colors under the UV light. Great work Peter, Ivo and Sander.
    l3p likes this.
  2. flix
    flix Minimodder
    5 Aug 2009
    Wow, I love them oO
  3. Egami
    Egami Why is the dremel on fire?
    27 Aug 2013
    Gorgeous stuff and so well executed.
    siliconfanatic likes this.
  4. r104_for
    r104_for What's a Dremel?
    8 Dec 2013
  5. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    whoooa :O! Those are some darn sick radguards :D!
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys!
    Time to get back on this project!
    Been busy the last few weeks with some other things that needed to happen first :)
    First ordered some more Q-blocks
    Think these will give a cool effect too.
    Something I did which took me a few full days.
    Cleaned up and re-organised the complete attic. :)
    And another thing I did..
    Probably the cheapest case I ever made :)
    'L3p Min3r'
    Desk for the 'clean' work.
    Also received something really nice from ASUS Benelux.
    Screams to be modificated ;)
    Such a pleasure to work in a clean spot ;)
    On to the next updates!
    montymole likes this.
  7. Nexxo
    23 Oct 2001
    Impressive man cave.
  8. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    I don't think I've ever had such a strong desire to explore a room before, that is heaven right there. That PCI-e SSD is ridiculously sexy too, got to hand it to Asus and their design departments.
  9. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    I NEED a mancave like this.
    Admittadly, I'd probably fangirl for a few minutes( in a manly way :worried: ), but the potential, oh, the potential.
  10. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys! :thumb:
    Decided to only use some handtools and a dremel this time :)
    First wreck it.
    And measuring the acrylic.
    First drilled the holes then used the fretsaw.
    You can easily drill holes near the edges with a dremel on high speed by the way without breaking it.
    And sanded the edges.
    More measuring.
    Always a lovely moment when you can peel off the protection layer :p
    Used transparent glue and left it to dry for a night.
    Then I found out I didn't have long M2 bolts after all ..
    So removed the standoff's and drilled all holes in PCB and covers with 3.2mm.
    Plenty of M3 here :)
    30 nuts later.
    And with some LEDS on.
    With his little sisters.
  11. montymole
    montymole Rigid Tubist
    24 May 2010
    As ever looks top class work
  12. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looking good Peter! That backplate for it works really well with the sticker. In daylight not too impressive but under Uv exactly right!
  13. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys!
    I'm still alive ;)
    Months ago I got the idea to have a PS4 on the right side, cooled with custom made waterblocks.
    However after months of doubt I have decided not to do this cause of the time and finances involved for this (MARSII block.. pfff )
    Last weekend I took a few hours to see how I will continue .. and .. I'm totally back :)
    Also will use the pumps and reservoirs separate instead of the combo's.
    And .. going to do 2 separate loops with each 2 pumps, however with the use of 4 valves I want to be able to switch to one huge loop with 4 pumps and 4 radiators.
    So .. another update.
    Used rubber again on top of the acrylic edge to hide the green top side and isolate the desk inside.
    Also 2 extra grills from ModWithMe which I will use on the inside of the desk.
    The Raz3rator.
    Finally I can mount all 4 Admirals
    Ook kan ik eindelijk alle andere radiatoren monteren.
    Number 1
    Two.
    Removing sticker from the other fans.
    Quite some bolts.
    Number 3 done
    Something I ordered months ago through Kickstarter.
    Ambilight :)
    More about that later.
    Also 2 long LED strips inside, nice effect when opening it :)
    And the last one.
    Number 4 .. done.
    This photo was made just after I decided to drop the PS4 idea and I was measuring it all.
    First make the reservoir covers a little more shiny .. not too much, don't want to see all the leds in detail.
    Sawn off all reservoir clamps.
    And another try :)
    You will lose the skin on your fingers ... but I love it! :)
    Testing how it will look with a Bitspower LED RAM MOD underneath.
    Means it will have the same 'heartbeat' effect as the Razer mice. (See video!)
    Will be a lot of measuring :D
    This is how the should work, and yep I often use paint for these kind of things :p
    Things could still change but personally I already like it.
    And a short video of how it's standing now.
  14. Asouter
    Asouter --------
    18 Jan 2012
    Freakin awesome L3p I'm love the colour combination and I'm trying to imagine the loop filled, with all the other light effects and acrylic panels. It's going to look soooo good.:thumb:
  15. SavellM
    SavellM What's a Dremel?
    19 Mar 2013
    WOW...
    Just WOW
  16. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks mate! I'm all enthusiastic ever since I placed those reservoirs lol.
    :thumb:
  17. JD Design
    JD Design What's a Dremel?
    13 Feb 2014
    very nice: Pouce:
  18. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Stop making us all have inferiority complexes about our machines please :D
  19. siliconfanatic
    10 Sep 2012
    Amen to that!
    If they handed out awards for most minds blown, this, would pwn!
  20. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    :eeek: :eeek: Immensely awesome work in here, just outstanding very well done :hip: :thumb:
