PSU Recommended PSU List - Listed On First Page
Discussion in 'Hardware' started by Moyo2k, 22 Aug 2009.
  1. azrael-
    azrael- I'm special...
    18 May 2008
    Or you could get the Seasonic X model, that the Corsair AX model was based on, which can actually be cheaper. :)
  2. kadombing
    kadombing What's a Dremel?
    24 Jan 2011
    Agree, but Seasonic over ~400W is so darn hard to get here in the UK. Sigh..
  3. blueviper11
    blueviper11 What's a Dremel?
    9 Sep 2010
    what about Coolermaster PSU 1200W Silent Pro Gold?
  4. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    1000-1200W ?
  5. CallumA
    CallumA What's a Dremel?
    1 Mar 2011
  6. Motoko
    Motoko What's a Dremel?
    8 Jul 2009
    Could you add the best fanless PSU's too?
  7. Skellig
    Skellig What's a Dremel?
    2 Mar 2011
    Budget as in a desktop no gaming build? Yes.
    But definitely go for solid name brands when you're looking to build even a low end enthusiast PC.
    I'd never skimp on a PSU but that goes hand in hand with knowing how much power your build will draw. No point getting a 1000w PSU when your maximum draw on Furmark barely scratched 650w. A 700-750w branded PSU will be more than sufficient.
  8. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Suggestions for Fanless PSU?
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  10. TheRealShep
    TheRealShep ssSSSsssssssSSSSSSSSSsss
    14 Mar 2011
    I just went onto the internet and used a "PSU Power Calculator" I filled in as much as I could and it told me I only needed a 34w PSU...
    Is this correct?!
  11. stonedsurd
    11 Mar 2009
    Unlikely. List the hardware you plan on using, someone will help you out.
  12. TheRealShep
    14 Mar 2011
    GTX460
    i3 540
    XMS3 2x2GB
    Nothing special I'm sure but I think I may have not clicked the correct thing somewhere!
  13. stonedsurd
    11 Mar 2009
    This link tells me that you should be looking at >500W.
    That's the most common site that people use for this sort of thing, so if you were on there, then perhaps you forgot to click the 'calculate' button?
  14. TheRealShep
    14 Mar 2011
    Thats the exact same site....
    <-------- Fool
  15. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Can I ask why the Seasonic X-Series, and the NZXT Hale PSUs aren't on the list? Especially in place of the Enermax Gold PSUs, as they are both cheaper than the Enermax PSUs, and get fantastic JonnyGuru and Hardware Secrets reviews, which, frankly, are the only two review sites that are worth reading about PSUs on (sorry Bit-Tech, though admittedly, I haven't seen a Bit-Tech PSU review...).
  16. Fingers66
    30 Apr 2010
    Because this list is very old, check the date the thread was started.
  17. Marvin-HHGTTG
    10 Oct 2010
    Ah, sorry, thought it was still being updated...
  18. TheRealShep
    14 Mar 2011
    What PSU would be best if I need a really quiet supply that is under 500w and within a £50-£60 budget?
  19. murraynt
    murraynt Modder
    6 Jun 2009
    You will run that rig on a 380 watt antec eathwatts.
  20. Fingers66
    30 Apr 2010
    Doesn't a GTX 460 need a minimum 450w?
