PSU Recommended PSU List - Listed On First Page
Discussion in 'Hardware' started by Moyo2k, 22 Aug 2009.
  1. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    CustomPC uses indepth ( not to mention expensive ) equipment in they're Labs test similar to that article. I wouldn't trust any other source for a PSU review.
  2. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    That's very encouraging /sarcasm, especially seeing as most of this info comes for bit tech/custom pc anyway and everything else is personal experience...
  3. trig
    trig god's little mistake
    10 Aug 2006
    might as well add the XFX 850W Black Edition Modular PSU to this list. Essentially a Seasonic M12D with even more impressive test results...
  4. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    added
  5. trig
    10 Aug 2006
    you're a good person, i don't care what bindi says.
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Lol, we all put up with bindi cos we love him really, although he is by far the most erratic moderator Q.Q :D
    And ty for the comment ;)
  7. tonschk
    tonschk Minimodder
    31 Jul 2008
    Hi there , I already replaced the noisy ball bearing fan with a GELID sleeve bearing fan ( lubricated by myself with a creamy Zirconium grease ) , now this Silencer 910W is finally total silent ,of course I swap upside down the direction of the airflow inside the PSU to allow only fresh air to enter into the PSU , the case is also a Silverstone RAVEN RV02 modded upside down , to allow vertical airflow please see the pictures
    I have found another intresting advantage of the PC Power & Cooling 80mm layout , the 80mm fan allow partial airflow below ( not only above ) the PCB inside the PSU , the 120mm layout fan cannot send airflow above the PCB of the PSU , therefore the air above the PCB of the PSU become hotter
  8. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    You could try directing a cooling fan onto it to keep the heat down... at the area where heat is trapped, maybe an antec spot cool
  9. tonschk
    tonschk Minimodder
    31 Jul 2008
    Hi there , my Blue gelid 80mm Fan send airflow above and below the PCB inside of the PSU therefore I have not problem , the people with problem with the heat trap above the PCB of the PSU are the people with a 120mm fan inside the PSU
  10. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    ahhh ok, ty for the heads up then
  11. unknowngamer
    unknowngamer here
    3 Apr 2009
    While not a super PSU, when on one of scans spechials it's great deal
    Scan do it fo £50 or £60 on a today only
    NorthQ Black Magic Flex 850W << 8.5/10 from jonnguru
    The other one is the "700W FSP700-80GLN" which goes for £30 on a today only
    which is the OEM version of the "FSP FX700-GLN"
    Shorter fixed cables, but alot PSU for the money, SLi ready 2x6pin
    Both PSU's are ok in their own right, but they drop to 1/2 price about once a fortnight.
  12. Carper
    Carper Guru
    19 Aug 2009
    i've been looking at getting the corsair tx650w but its not on this list. anyone know if its any good?
  13. Krikkit
    21 Jan 2003
    It's good but old now. Go for the BeQuiet 650W and be happy. :thumb:
  14. jcrider
    jcrider Minimodder
    27 Sep 2009
    I'm looking at either:
    • Be Quiet 650W Dark Power Pro - £101
    • Antec TruePower New 650W Modular - £89
    • Corsair TX 650W - £73
    With almost a £30 difference would the Corsair be a better choice?
  15. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    I'm quite happy with my Be Quiet! Straight Power 500W. £80 it cost me when I bought it late 2007. Wish it was modular though..
  16. Carper
    Carper Guru
    19 Aug 2009
    Thats about £100 though another £30 on top.
  17. WILD9
    WILD9 Been here aaaaages
    13 Sep 2001
    The corsair HX-850 is modular, the list shows it as non modular.
  18. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Thank you very much, have some rep
  19. MicroDom
    MicroDom Dom
    5 Oct 2009
    Great Idea :thumb: although you could have put them in order of there stars as well as there watage :search:
  20. talladega
    talladega I'm Squidward
    18 Aug 2007
    I'd recommend the Silverstone ST75F. It is a 750Watt Modular power supply. Works great and every single cable is modular and uses standard connectors on the PSU end except the SATA power connector. I love mine.
