Scratch Build – In Progress ROG Max V,MOTY Nominee .
Discussion in 'Project Logs' started by nhenhophach, 5 Jun 2012.
  1. nhenhophach
    nhenhophach Bit-tech
    16 Aug 2007
    Max V
    The case with name from ASUS MAXIMUS V Formula motherboard, it l will exhibit at ASUS booth
    i started this project 2 month ago, but i can post worklogs now.
    Sponsor:
    I got Hardware from Sponsor
    Time too short so i can't design with Sketchup, i do with Acrylic first then change to Aluminium some parts.
    Laser cut Base and TOp of case.
    Shaped aluminum
    TAP.
    Assembly into the base
    Acrylic tube OD/30mm
  2. nhenhophach
    16 Aug 2007
    Make main tray.
    I want put Thunder FX to case too, so i need space.
  3. nhenhophach
    16 Aug 2007
    My idea is use two Acrylic tube become reservoir so i have many of work to do.
    Lathe solid Acrylic.
    Prepare material,
  4. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Looking great so far!
  5. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    I like this style of case, this one is looking great so far
  6. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Looking good, how did u mount the videocard?
  7. Guest-16
    Guest-16 Guest
    I'd like to also say that Ban not only made this, but the flight case for it too. All in about 6 weeks! It's on the ASUS booth in Computex both 100% working and 100% perfect. The man is not a modder, he's a miracle worker. :rock: You have our utmost thanks!! :rock:
  8. Cheapskate
    13 May 2007
    Awesome!:D
  9. nhenhophach
    16 Aug 2007
    I use two reservoir keep two doors too. So i add some ball bearings
    Acrylic pices will hold Therdex FX and look better.
  10. nhenhophach
    16 Aug 2007
    Receive goods from BITSPOWER.
    Carbon Black.
    Đây là số Fitting sẽ được dùng cho case, phần trong bọc để dành.
    Continue work
  11. nhenhophach
    16 Aug 2007
    I change some parts from Acrylic to Aluminium.
    Nhôm 5mm.
    CNC
    Motherboard TRAY
  12. Djayness
    Djayness phwupupupup
    7 May 2008
    Excellent work. Not to ruin the end of the mod but there's some flashes of it at 44 and 55 seconds in this video.
  13. KryptiK
    KryptiK What's a Dremel?
    12 Jan 2012
    amazing! subbed
  14. amagriva
    amagriva Minimodder
    13 Jun 2009
    to give us un unwanted asus commercial you did spoiled the log...:wallbash:
  15. Djayness
    7 May 2008
    You do realise that;
    1. ASUS ROG sponsored the build.
    2. The mod is on show at Computex 2012
    3. The video linked shows you the mod and my word, it's absolutely brilliant.
  16. nhenhophach
    16 Aug 2007
  17. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thats an epic mod!!!!!!!!!!!!
  18. l3p
    l3p www.^.nl
    1 Nov 2010
    Ban, you're my hero!
  19. nhenhophach
    16 Aug 2007
    Making TOp of case
    Interconnected Plate
  20. nhenhophach
    16 Aug 2007
    Make two doors
    I used plenty of Acrylic pieces
