News Sapphire brings Vapor-X tech to CPU cooling
Discussion in 'Article Discussion' started by Gareth Halfacree, 30 Nov 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    Review incoming?
  3. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Interesting ... waiting for reviews :D !
  4. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
  5. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    I need to see a review on this as these type of CPU coolers have been tried before and failed.
  6. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    Can we stop with the whole bit-tech 'can dissipate x heat'? Of course it can dissipate 200W heat; anything can dissipate 200W heat. Seriously, if a pinhead were at a sufficient starting temperature it would be able to dissipate 200W heat at room temperature, because the temperature gradient would be high. Even the Artic Cooling Freezer 7 Pro was marketed at being able to dissipate 200W heat, back in like 2007.
  7. Roskoken
    Roskoken What's a Dremel?
    15 Jul 2011
    To think google have been spending a fortune on elaborate server cooling for all this time when all they needed were some pins!
    You should email them RIGHT NOW with your theory.
  8. foxrena
    foxrena What's a Dremel?
    1 Dec 2012
    It's funny everytime I see comments like yours. You think you know but you don't.
    This is simple physics... claiming 200W heat dissipation is meaningless if no temperature difference is given. It's just a way of advertising for the company. I would hesitate buy such a product if I see these misleading ad numbers.
    What truely matters for a cooler is the C/W ratings, as should be used by all cooling enginners. Anything can dissipate 200W, @Bakes is right. The stock cooler can dissipate 200W of power when it's 30C higher than ambient while a high performance cooler dissipates the same amount with maybe only 10C higher than ambient. When you compare 0.15C/W with 0.05C/W, you know which is better.
    Sapphire engineerers know this. But their marketing department do not care.. They will just throw out a numbe .... 200W, sounds plenty, Ha!
  9. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
    What Bakes said is physically accurate. Newton's Law of Cooling says that heat transfer is directly proportional to both surface area and temperature difference. If you make either one of these values large enough, it compensates for the other.
  10. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    Looks like Darth Vader built it....
  11. Roskoken
    15 Jul 2011
    Only if its linear
  12. feedayeen
    18 Jun 2008
    I figured you would have dropped this. Newton's Law of Cooling applies to the lumped capacitance model of thermal bodies where temperature remains at a constant temperature inside both bodies. This improves the rate of heatflow since the gradient is so narrow. For small or metalic objects, it's a good approximation, for air, not so much since the thermal conductivity sucks. But even when you factor this in, you wind up with a temperature curve that looks like 1-e^-x with some constants to scale the amplitude so that x=0 produces the temperature of the heatsink and another to determine the half life.... but even this is linear since the derivative at x=0 is proportional to the temperature.
    I've already determined that it's linear so I could stop this right now, but it's actually better than that. If you get really, really hot, well above what semiconductors can survive at, maybe 500-1000C depending on geometry, the warm air will have significantly less density than cool air, convection has now become a major force.... In practice, it reduces the size of this half life and thus makes the derivative at the boundary x=0 larger, thus more heat flow.
    You then have blackbody radiation, which is proportional to 1/(e^(1/x) - 1), this curve starts out less than linear and it's one of the least efficient modes of heat transfer, but it accelerates slowly.
  13. Bakes
    4 Jun 2010
    Shh you. Even if we completely ignore Newton and just stick the pinhead computer in space, by the time we reach 10000C it's emitting about 500W in black body radiation alone. If you can make your components survive temperatures of 10000C, then by all means attach a pinhead for cooling purposes, because it'll get the job done.
  14. Kris
    Kris Lord Lolwut
    6 Jun 2008
    I love the discussion - who knew you could get from a CPU cooler to black body radiation with only so few comments. :)
    In all seriousness though: what if sapphire actually, against all odds, took the number 200W as it's "normal" mode of operation and performance as compared to the competition? (like keeping a 3960X at 50C while it is OC-d to 4,5GHz or whatever) One can hope. :)
  15. Gareth Halfacree
    4 Dec 2007
    If Sapphire had released any other figures, you'd have those too. As it is, "can dissipate 200W" is as close as the company has got to talking about performance. If it makes you feel any better, assume a worst-case scenario of "can dissipate 200W of heat without allowing the CPU temperature to raise to a point where it would trigger the chip's thermal cut-out."
    In other words: yes, a pin head could dissipate 200W of heat - but not without raising the CPU temperature to a level at which it stops operating. The Vapor-X CPU - and any other cooling system that says "can dissipate XW" - by contrast can.
  16. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    My GPU uses a similarly hyped "vapour chamber" style cooling and although it works well, it's still a bit of a gimmick. Heatsinks do what they are meant to do: they take heat away from the component and dump it.
    If anything, this heatsink has arguably missed the bus by going the 120mm route; the very best air coolers are all 140mm and it's unlikely that a 120mm heatsink will be able to compete, whether it uses vapourisation or not.
    EDIT: the "dense aluminium fin stack" is also a bit of a step backwards... all it means is that the cooler will need powerful fans for optimal performance (or, conversely, that it will fail dismally when furnished with quiet fans).
    EDIT 2: The American spelling of Vapour is really bugging me. :D
  17. jamsand
    jamsand Minimodder
    21 May 2011
    Looks like it'll be loud as hell, 40 at 2200rpm!!! I'll stick with my silverarrow or d-14
  18. Gareth Halfacree
    4 Dec 2007
    Same. It's a proper noun, sadly, so I have to override my fingers every time I try to 'correct' it - i.e. every single time I type it...
  19. Bakes
    4 Jun 2010
    Yes, it's all you've got, but it's a totally useless piece of information, because it tells us nothing about the quality of the cooler. For example, a standard 3770k will throw out about 77W when not overclocked; basic electronics tells us that if at 5GHz with a fairly dramatic 1.45V vCore it will be sticking out about 148W - which is enough for an Artic Cooling Freezer 7 Pro v2, which is rated at 150W (sorry, didn't mean 200w in the previous post).
    Would you want to run those settings with a Freezer 7 Pro? Probably not.
    All the numbers are saying is that what they've come up with is at least a viable CPU cooler. < Not interesting info.
    There's not really any point attempting to quantify it/buying into the marketing info; the information means nothing, because any modern processor would be running at obscene speeds before it would actually release that much heat (I may be overlooking some of the Sandy Bridge-E parts here). < my point
  20. Harlequin
    Harlequin Modder
    4 Jun 2004
    silverarrow is noisy as heck compared to my passive hyper Z600 :D
