News Sapphire launches new Radeon HD 4770
Discussion in 'Article Discussion' started by Sifter3000, 20 Aug 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    Nice. Great price point, especially with the custom cooling solution. Dunno about the blue PCB though...
  3. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    I picked one up without difficulty to be honest. Maybe I was just lucky. Either way, it's a fantastic little card. Whisper silent underneath my other components and a good 40 degrees (seriously) cooler than my old 7900GT. And given my little 1440x900 monitor's max resolution, it eats most games for breakfast. I'd still recommend it to anyone.
  4. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Forget the 4770. Will these yield problems affect the up coming DX11 cards?
  5. Rkiver
    Rkiver Cybernetic Spine
    23 Apr 2009
    Nice card, good price point and performance, will recommend that for anyone just wanting a simple enough machine that can play the odd game or two.
  6. Baz
    Baz I work for Corsair
    13 Jan 2005
    HD 4870's are only £110 now. just saying!
  7. The_EXorcist
    The_EXorcist Possibly Australian
    14 Oct 2008
    yeah, too little too late, the release of the 5xxx series is just too soon for this card to be an attractive buy right now
  8. badders
    badders Neuken in de Keuken
    4 Dec 2007
    TBH, I don't think I'm going to buy any new Graphics card until the performance jump is similar to what I did last time:
    Radeon 9800 Pro 256Mb -> 8800GT 512Mb
    Got a generation or so to go, methinks!
  9. Bauul
    7 Apr 2007
    My all time favourite card this. It was just the bomb.
  10. badders
    4 Dec 2007
    It's still going Strong! - My fiancee's uncle has it, playing Halo and HL2 at 1280x1024.
  11. Elton
    23 Jan 2009
    Why does sapphire insist on using D-sub?
  12. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    For us diehard CRT luddites, mainly - though I've had to use a DVI converter so often that half the time I just leave it on there, even when using an old card like the 9800.
  13. Elton
    23 Jan 2009
    My other rig uses a CRT...
    There's an adapter for that. Of course that GPU has a Dsub...
  14. papalarge123
    papalarge123 Papalarge
    8 Jul 2009
    well, when u consider the Asus HD4850 with the custom cooler (which runs 10c hotter than the HD4770) can be picked up for £75 from scan
    http://www.scan.co.uk/Products/512M...GDDR3-GPU-625-MHz-800-Cores-2-x-DL-DVI-I-HDTV
    it kinda makes the HD4770 slightly redundant as the HD4850 is slightly more powerfull and also cheaper.
    plus the fact that i own the same Asus HD4850 in the link and it runs virtually every game on full @ 1680x1050 res lcd monitor.
    the next purchase for me tho will be when the 5-series cards are out and have dropped to the £150-£200 mark.
    still tho, great news that ATI have solved the 40nm issue and that Saphire have come to the rescue with a newer designed board.
  15. Horizon
    Horizon Dremel Worthy
    30 May 2008
    well, in a perfect world they wouldn't have had yield problems and the cost of manufacturing would have been reduced making this card probably even cheaper. That said, the 4850 overall is marginally faster than the 4770 which usually comes very close to the 4850's performance, and many times even trumps it. My question is doesn't this card make the 4850 redundant?
  16. Elton
    23 Jan 2009
    It should make the HD4850 redundant, but as you an see, there's a shortage of said HD4770s.
  17. Horizon
    30 May 2008
    :facepalm: It was a rhetorical question.
  18. Elton
    23 Jan 2009
    But...but....it is....:)
  19. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    With HD4850's available at around £70-£80 and HD4870 / GTX260's available for a little over £100 this is too little too late.
    Now all we need now is some killer titles to justify the next gen cards.
  20. biebiep
    biebiep What's a Dremel?
    12 Dec 2007
    *drumroll*
    Crysis
    (someone had to say it)
Tags: Add Tags
