Hold out on the fanbus, if you want, you might be able to control your fan speed via software soon, http://forums.bit-tech.net/showthread.php?t=55191
Just on and off? You can do that through software now, if your interested, but only between 4 things. Your call
peel that horrible yellow/orange sticker off the psu and polish the visible sides. little dremel felt wheel and brasso action should make it happy, and then it wont compete with the frosting.
Nice but having the unmodded PSU behind the frosting kinda kills it. It'd look really good with a window and LED fan added inside the PSU.
Yes, I will take the label of, But ill do this when I get some braided sleeving to cover up the wires, then I wont have to keep taking the PSU it in and out. A window would look good especialy with led fans I was thinking of doing this, when I have done the other things to it (all in one go) I am adding switches for the other led fans to turn of when im asleep so having led fans in the PSU would defeat the object as I wont be able to turn the led’s off. Thinking of changing them for some quieter fans to put inside. Yes I do agree, and its just different as well.
Yeah the gold of the PSU doesnt look quite right in the case, when the lights are off you cant really see it. Have u thought about getting a bl00 led fan for the heatsink as the greeny/blue doesnt really go, at least cut the yellow asaka band off it. You can get a direct replacement, bl00 fan up the road a novatech for £5.88 not cheep but is identical to that one (no grill though) Like the case, carry on with it, looks good
I agree, remove that power supply sticker>>PLEASE. http://server6.uploadit.org/files/jeffrey9-IMG_0490.JPG
i think everyone would agree, take that sticker off i have been waiting for a clear cover for my psu, i have seen it done and it really makes a difference, especially with a led fan in there
YES I WILL TAKE THE STICKER OFF!!, but i dont wanna have to keep taking the psu in and out, il do this when i have the braided sleeving to cover the wires and the plexi for the window.
So, does that mean you are going to take the sticker off?? Looking good, really like the way this is coming out.
i know what you mean, i hate taking my comptuer apart to make a small adjustment, its really annoying, but sometimes it just has to be done.
PSU Mod! Hello modders. Update on Savage PC: PSU Mod Two things to be done: 1) Sleeving the cables and 2) A side window. Here it is, it’s a Q-TEC 550w dual fan gold PSU. The first thing was to sleeve all the cables with black braided sleeving, which I obtained from RS. (not a lot of pics on this, but I took all the Molex plugs of to slide the sleeving on and then heat shrink (took me about 3hrs to do it). Then the second thing was to cut a window, but first I decided to get rid of the yellow sticker on the side (which was not easy) The sticker had a thin piece of plastic that came off with ease, then scraping the rest of. However, it left a gluey surface. I used some Surgical Spirit to wipe it of … ….and clean the surface. Now for the cutting of the widow. I recently brought my self a Rotary Tool Kit (Dremel) it’s a Challenge Xtreme from Argos and at £25 with lots accessories it a bargain! Back to the mod, I cut a rectangle out of the side. I filed and sanded the hole for the window. I made the window out of a clear cd case and sanded it down to the prefered size and stuck it on the inside of the PSU lid with double sided sticky tape. Here is the completed PSU with fitted window. Here is a few shot's of the PSU inside the case. (looks like there is nothing in the PSU lol)
i cant see any of the pictures in this thread, i just get an "images hosted by angelfire" image. Im off to check them out properly as i have a new chieftec BX, just thought id let you know. edit cant seem to get them even when i go here: http://www.angelfire.com/folk/upload/images/35.jpg
Yes I know for some gay reason, i have to view every pic in angelfire when loged on which will view them on bit-tech, but after a while they disapera again, well anoying! The BX case's are good thou!
just to help you out with stupid angelfire. Upload the image, rename it to .txt eg http://www.angelfire.com/folk/upload/images/35.txt and then submit with the
