Scratch Build – In Progress Scorpio-completed
Discussion in 'Project Logs' started by Pranja, 15 Oct 2012.
  1. Sissilisko
    Sissilisko What's a Dremel?
    26 Apr 2012
    nice to see it getting it's final form, keep up the good job! :)
  2. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    To be honest, I didn't like the first version at first sight, but the second, the evolved version will be very nice work!:thumb:
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Well,I am glad that my bad photography skills helped your project. :D
    Thank you Sissilisko-I will. :thumb:
    Well, it was prototype-prototypes never look good. But I am glad that you like mark 4. :clap:
    Some pics of rad fit testing:
    100+ posts. Thank you for being such great support.
    This is also first anniversary of start of my modding adventure.
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Not been keeping a close enough eye on this, looking awesome Pranja. :clap:
  5. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    oooh, this is going to be great! :)
  6. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thank you Waynio-I appreciate it. :)
    Thank you kelmannen. I am glad that you like it.
  7. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I made a custom thermometer for water inside reservoir.
    Items used: one fitting,teflon tape, cheap ebay digital thermometer, a little bit of hot glue.
    Also,some new parts arrived.
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    That's a heck of an awesome motherboard tray. :)
    Actually, that is a motherboard tray isn't it?. :D
  9. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Yes, that is MBO tray. :D I am glad that you like it. :thumb:
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Update- I glued PSU holder-now it is a black and transparent version and fits nicely with case color scheme.
    Design and holes of PSU bracket are changed a bit.
    Gluing the part in its place.
  11. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    I'm liking it dude! Keep 'em coming! :)
    Pranja likes this.
  12. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thank you. :thumb: I will.
  13. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Looking good!
  14. Asouter
    Asouter --------
    18 Jan 2012
    Nice project, I have some nylon spacers (8mm) which would be much kinder to your plexi than those bolts, I used them on deep thought ....If you like I could send some through if it'll help with your build
    PM me if you're interested
    A pic of how I'd used them
    Pranja likes this.
  15. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thank you. :thumb:
    Thank you Asouter-that is very kind of you. I am grateful for your offer. :thumb:
    But I allready decided to use plexi tubes as spacers. :)
  16. Asouter
    Asouter --------
    18 Jan 2012
    No worries Pranja, just noticed the unjust 3 star rating, voted for 5 stars to bump it up
  17. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thanks for the rating Asouter,but I those stars don't worry me. :D
  18. Cheapskate
    13 May 2007
    Just a heads up: I used hot glue long ago in aquarium related stuff. It's not very good at sealing water. The seal will break with a little pressure/thermal expansion/etc..
    Update faster.:D Please.:D
  19. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Don't worry-I used teflon tape for sealing water. Hot glue is only used to keep everything in place. :dremel:
    I wish I could update faster-but it is not up to me. Sorry. :(
  20. Pranja
    Pranja Blackwolf
    18 Dec 2011
    PSU tray is finished and dead PSU is placed for testing.
