Scratch Build – In Progress [Scratch Build] 'Completed' Project Ethos & Cube - The Baby Grand
Discussion in 'Project Logs' started by SavellM, 19 Mar 2013.
  1. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Thanks! Looks like they don't have any for 12mm OD, just 13mm..
    Anyway, polished copper pipe is probably going to look awesome in a wood desk :)
    A little hint that might come in handy for you: The pipe bender I used was really crappy quality. So for getting good bends, you need to fill the pipe with sand and close it, and some spray like WD40 can also help getting a nice bend. Have fun! :)
  2. SavellM
    SavellM What's a Dremel?
    19 Mar 2013
    Thanks mate :)
    My brother is a plumber so has all the tools, and expertise.
    I will be calling on him to come and do all the bends :D
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    I really like how it's living up to the name, desk of awesomeness. :D
  4. dreps
    dreps Minimodder
    3 Oct 2012
    you should call this desk project awesome man :D
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    Got a funny shape & I see a little element like a grand piano, very nice. :)
    I recently seen ET's face in another project which was also awesome. :lol:
  6. SavellM
    19 Mar 2013
    Thanks guys :)
    Yup a few people have said its a baby grand piano, I take it as a compliment haha.
  7. SavellM
    19 Mar 2013
    Bit of an update from today.
    Did:
    1) Make cover for Blu-Ray drives
    2) Mount vandal switches
    3) Drilled holes for mobo tray
    3) Cut outs for cable from PSU at the back
    4) Run network cable under the carpet to link the desk to the TV unit
    Designing and thinking of the cover:
    Measuring out my idea
    Messing with the pumps moving them around for seeing the space
    Back to making the Drive cover
    Glued together and small nails
    Looks nice and covered :)
    We will stain it to match the colour of the desk
    Mounting the power and reset switches for both machines
    From the back did a larger hole so that we could use the nut
    All 4 holes done.
    Top 2 for power switches
    Bottom 2 switches are slightly smaller and these are reset
    Reset switches
    Switches fitted from behind
    Marking and drilling holes for where the mobo tray fits into
    Cut out the back for where the psu and power cables go through
    It needs to get sanded down and also another tool to cut it straight (didn't have it on us :()
    Back cut out for cables for mobo
    Network cable run under the carpet, nice flat cable
  8. SavellM
    19 Mar 2013
    Sorry there hasnt been much of an update.
    Life has been hectic!
    But here is a small one from last night.
    Sanding down the side, getting rid of the filler
    Stained the Drive bay cover
    Doing mounts for PSU
    It actually hold the PSU in really well!
    How it will look with the other PSU once I get it
    Side is stained, but you can see the join unfortunately.
    In person it doesn't look so bad
    Screwed down the mounts for Mobo tray
    With the tray
    Then we had another issue to take care of, my Chair...
    I needed to remove the arms, as they were not allowing the chair to slide under the desk fully.
    So one would think it would be simple as removing a screw or bold.
    But no... This one had an double lock mechanism.
    So after some sweat and frustration the head got stripped.
    Next thing... Drill it out, as I was over it!
    Phew it came off!
    After that it was finish fitting the middle rad
    Had to counter sink the screws again
    All fitted nicely
  9. SavellM
    19 Mar 2013
    After that we made some little risers for the Res so that they stay above the pumps
    Then back to finishing off the staining
    After the stain is dry its varnishing time
    Even the little risers get the treatment
    Last thing we did was to fit the handles for the draws:
    Measuring out
    All done
    That's it for now...
    Hopefully do a bit more here and there.
  10. Cheapskate
    13 May 2007
    Looking great.:D You haven't finished yet, and I see it's already full of old lighters.:lol:
  11. SavellM
    19 Mar 2013
    Haha well spotted.
    Most of them are still full, or half full.
  12. scrivz69
    scrivz69 What's a Dremel?
    19 Aug 2009
    A fantastic build log thanks for sharing.
  13. SavellM
    19 Mar 2013
    Found a bit of time the other night.
    Decided I would try laying the Vinyl...
    Oh man it was a lot harder than I thought it would be.
    Took about 3 and a half hours.
    Prep, removing everything form the desk and making space
    Rad mounts removed
    Sanded down the desk, not much but just so its silky smooth
    Put the vinyl over the desk just to make 100% sure its large enough
    Did a quick cut out of the corner, thinking I can then just push it up and cut it closer after
    Didn't go like I had imagined
    Figured out another solution, make a template
    Cutting out the vinyl... (In hindsight I should have made a template for the whole desk!)
    Fits much better now
    Laying it out
    Going over the little back part
    Not too bad, but unfortunately the wood had a cut mark, which shows in the photo.
    It doesn't show in real life unless you look really hard
    Carrying on, and going down
    Finishing off the bottom section
    Cut out for the middle Rad
    With Rad cover fitted
    And the mess that is perfection!
    Next step is to run some black silicon around the edges to make it look finished around the edges, and to fix a few of my balls ups!
    That's all for now :)
  14. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    All that nice stylish and tasteful wood and then...................................... Carbon wrap... :waah:
    Looks good none the less. ;)
  15. SavellM
    19 Mar 2013
    Lol so many mixed feelings on the wrap :(
    Oh well, my feeling was I can always peel it off if I don't like it.
    But you are also looking at it as it is... It looks way better with the hardware inside too.
    And when you step back, the whole desk is wood, just the inside bottom.
    Dont forget there is a top still to go on as well ;)
  16. The boy 4rm oz
    10 Apr 2008
    The carbon fiber really looks good against the wood, nice choice :thumb:.
  17. SavellM
    19 Mar 2013
    So started a bit with the fan assembly and silicone the edges of the desk so it looks better.
    I didn't take to many pics while doing the silicone so will finish it first and then show you pics.
    But here is a sneak so far:
    So anyway got to joining all the fans.
    This was my first time ever Soldering... So go easy on me
    Cutting fan wires to length
    Then joined them up
    Just need to shrink wrap around the joins, and put the fan connector on the other side.
    Test and should be good to go... Hopefully...
  18. SavellM
    19 Mar 2013
    So I went back after some advice and removed the extra 2 yellow wires.
    This is so that I can get a clean RPM readout on the fan controller.
    Also fixed up the solder so it looks better and is cleaner.
    Then shrink wrapped the joins.
    After that I decided to de-solder the yellow wire from the fans themselves.
    Just to keep a clean line.
    Next up gotta fit them in place and check the fittings and make sure they work.
    Then sleeve them and run the cables around the desk.
  19. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    I was gonna ask about the RPM wires, good thing you fixed it :)
  20. SavellM
    19 Mar 2013
    So mate got back and so it was time to get back to the desk.
    First things first, to clean up and do another silicone seal around the edges.
    Man that Mobo tray needs a bit of a clean, sorry :(
    All prepared!
    Measured out to sink in the mobo standoffs
    Down she goes!
    You can see how deep we are sinking the server standoffs
    Cut through the carbon OK
    All cleaned and all 6 standoffs in
    Tray fitting
    Nice!
    You can see how close it measures up with the lid on
    Silicone re-done
    All done
    PS. that back wall got another coat of stain last night.
    To make it look more even, as it was a bit blotchy when we made the hole cut outs.
    That's all for now.
    Waiting for my other parts to come into stock!
