Seagate 160GB 2.5" Portable Hard Disk
Discussion in 'Article Discussion' started by Tim S, 3 Feb 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    Looks nice. I have 3 usb on my laptop one on the side and 2 on the back under a flap. I always use the one on the side as its easier to get too. If i had to use the 2 on the back id probably end up with it broken.
  3. Guest-18698
    Guest-18698 Guest
    used this and its good. however i opted for a 320gb maxtor for £71.99 pc world :)
  4. David_Fitzy
    David_Fitzy I modded a keyboard once....
    8 Jan 2004
    heh I just bought a Generic 2.5" USB box with a WD 120G in it. But rather than use it as is I'm going to swap the 20GB in my lappy with the WD in the caddy when I return to the UK.
  5. LAGMonkey
    LAGMonkey Group 7 error
    4 Aug 2004
    so let me get this strait. it needs 1 AMP to run?! and its a 2.5inch laptop HDD?!!!
    surely this cant be right? you generally only require 500mA to run a laptop HDD so the rest must be used to power the blue light!
    or have a really missed a trick with this one? :lol:
  6. Guest-23315
    Guest-23315 Guest
    Looks good, but my 80Gb Wester-Digital Passport drive only needs one USB port, and is slightly smaller, and cost under £50 from Amazon on a deal.
    Still, i love my portable HDD, and if this gets people go buy them, then it all good.
  7. Guest-16
    Guest-16 Guest
    Max Amperage (Amps?). Spinup power is significantly more than idle running.
  8. RTT
    RTT #parp
    12 Mar 2001
    USB is low voltage though (5.5v max?) so it'll probably be running it through a step-up transformer to double the voltage and halve the current back down to 500mA. (and in either case it's still consuming the same amount of power (W)). :thumb:
  9. Krikkit
    21 Jan 2003
    Don't forget the power needed to power all that bluetooth/WiFi jiggery - that stuff isn't exactly low-power either... :)
  10. led_zeppelinzoso
    led_zeppelinzoso What's a Dremel?
    13 Jul 2006
    I have this drive, and I was suprised to find out that it works with only one USB pluged in, or just a normil USB cable, atleast on a desktop. I'm going to try it on a laptop sometime.
  11. Guest-16
    Guest-16 Guest
    Yea they work on 1 plug just fine most of the time, but you are maxing out that USB port.
  12. led_zeppelinzoso
    13 Jul 2006
    So... am I safe, or what? is it ok to do that???
  13. Krikkit
    21 Jan 2003
    You're probably safe, but remember that you're running on the ragged edge of what is and isn't supposed to be done, it's better off with 2.
  14. Guest-16
    Guest-16 Guest
    I've been doing it for months on both laptop and PC with just one.
Tags: Add Tags
