Silent Suitcase - Ultimate silent LAN suitcase
Discussion in 'Project Logs' started by AutoExec, 21 Dec 2004.
  1. TerraMex
    TerraMex What's a Dremel?
    8 Mar 2003
    True, but you can go ghetto and use some cable sleeve (spiral wrap) or some copper (other?) wire on the ouside to give the same effect.
    I've seen another type of those "cool sleeves" (product) but fitted in the tube wall itself (part of the tube ). No link. Dunno where it was.
    Or you could just use a spring to do the same , on the inside of the tube (just make sure it's copper , corrosion is a nasty thing), similar to the electrician's method of bending pvc pipes :) (hate it, had plenty of experience on that a few years back).
    Anyway, just a few ideas.
  2. AutoExec
    AutoExec What's a Dremel?
    31 May 2004
    dont know exactly why, but I REALLY dont like those coolsleve thingies.. looks too "plastic" I guess.
    About going ghetto: neh :) I've seen lots of ghetto computer suitcases, so I'm goint to try to make this as unghetto as possible.. in the end at least :)
    There are other ways to keep the tubes from folding.. one is to fasten them to something else (like the dvd burner) at points around the turn. I might try that, but a lot of the 90 degree bends will still have to stay.
  3. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    u could get some primaflex tubing from www.voyeurmods.com
    probably couldnt make some of the turns, but it is pretty flexible without flattening...
  4. uwannabigmak
    30 Dec 2004
    o, and if ur still looking for radiator fans, silenX.com has 11 dbA fans... decent flow (about 40 cfm i think, too lazy to look up)
    there really expensive though
    they also have a 14 dbA with better flow (58 cfm
  5. AutoExec
    31 May 2004
    I've never been looking for radiator fans. The project is fanless.
  6. jezmck
    jezmck Minimodder
    25 Sep 2003
    looks like a great idea - really hope it works.
    and to those that didn't, :read:!
  7. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    i like to see how you are going to fit it all
    good luck :D
    make it a beauty :D
    *subscribed*
  8. AutoExec
    31 May 2004
    a subscription.. how cool :D
    I've actually just picked up the innovatek radiator and the peltier elements from Acid Burn who brought them to me from Belgium :) Thank you!!
  9. KAMIKAZE-FREAK
    30 May 2004
    Then hurry up with the next update :D !!
  10. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    i plan to make a second suitcase rig, o got uni...it will be ir coole as my main rig is keeping the Watercooling....but very intrested in ho u make it all fit keep it up :)
  11. Hyjnx
    Hyjnx What's a Dremel?
    16 Sep 2003
    any updates? looks like it was going good...get some pics in here
  12. AutoExec
    31 May 2004
    Hang in there.. still on vacation!! :)
    going home tomorrow night
  13. AutoExec
    31 May 2004
    right.. this kind of hurts my wallet a bit, but I've found out that I might be able to stuff in another Eheim1250 pump... think that would help on the flow issue? :)
  14. automagsrock
    automagsrock What's a Dremel?
    18 Nov 2004
    This is definately a cool idea. Can't wait for updates and pictures!! :clap:
  15. MiNiMaL_FuSS
    24 Dec 2003
    i think a single 1250 will manage it anyway m8, while arguably u have alot of angles slowing things down, u also have alot less tubing to get through as everythings very close together.
    Get a 'Hydor L30 II' instead, cheaper, quiter, smaller, and just as strong as a 1250....i have both, trust me ;)
  16. AutoExec
    31 May 2004
    hmm.. how large is that hydor pump? I have set up the system to fit a 1250 now, so inserting a new part with different measurements wont be all that fun, believe me!
  17. djfrexx
    djfrexx What's a Dremel?
    27 Dec 2004
    looks nice :rock:
  18. ballemann
    ballemann What's a Dremel?
    6 Nov 2004
    question for you autoexec, oslo? hvordan kom du deg til treffet da? :idea:
    btw : nice, and TIGHT case :hip: :dremel: :D
  19. AutoExec
    31 May 2004
    ballemann: Glemte visst å forandre location fra Oslo til Trondheim når jeg flytta i August :)
    tight indeed!
  20. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Now just if you guys could translate that for me.
    Love ths project
