Case Mod - In Progress Silver Dragon "Video" Pag22
Discussion in 'Project Logs' started by ulysses Cazuquel, 1 Apr 2007.
  1. pedrofilho
    pedrofilho What's a Dremel?
    4 Apr 2007
    What color you intend to paint the case?
    See you fellow citzen,
    Pedro Torres.
    BTW-> Don't forget to rate my thread. I need help, some one has cheat on me and rate a low star. tnx.
  2. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    The color would be Mother of Pearl...or thats what I call it :)
  3. ulysses Cazuquel
    ulysses Cazuquel Sex, Casemod & Rock'N Roll!!!
    29 Apr 2006
    Thanks Dean MF,
    Initially this sticker will be placed in each acrylic but it appeared me an idea of using those stickers and another thing.
    Later I reveal what will be
  4. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    i'm shocked ! nice job, i'm only curious about type of cutting blades that U have used to cut side pannels (standart dremel rainforced blades ? ). I'm modding now Chieftec dragon case(1mm steel plates) and rainforced cutting blades are to weak for that :D
  5. hu$tla
    hu$tla What's a Dremel?
    19 Jun 2007
    good seen, very excellent work. I like your dragons they look awesome, keep up
  6. ulysses Cazuquel
    29 Apr 2006
    Thanks very much HeXeN,
    Here the letters that I go to use in slot and that it has a reflect effect
    These are images taken off in the dark one with flash
  7. nissanskyrice
    nissanskyrice Terminally Lazy
    10 Jul 2006
    Ive had the same problem. I just ordered a diamond cutting wheel dremel part #545 if i remember correctly. theyre expensive but apparently worth it.
  8. Teyber
    Teyber ******
    18 Mar 2007
    Dude, go get the diamond cutting wheel: now!
    ive had mine for like 3 months, use it daily(literally), and cut through metal as thick as 1/8". A must have! its like 10 bucks though....
  9. ulysses Cazuquel
    29 Apr 2006
    Thanks nissanskyrice HeXeN Teyber
    I use cutting wheel dremel part #409 that is the minor cutting wheel
    because it is better to make cuts minor and round
    The cutting wheel biggest part #420 are best for straight cuts
    the diamond cutting wheel part #545 they are best for straight cuts and mainly where the metal is harder
  10. ulysses Cazuquel
    29 Apr 2006
    Image of the finish of the cut dragon that it initiates today
    I must continues the finish when to initiate the new cut next week in the project
  11. ulysses Cazuquel
    29 Apr 2006
    I bought 33 of the stainless steel screws of 3mm and more 15 stainless steel screws of 5mm to be used in the Coolers
    But the screw of 5mm was great then will have that to change for of 4mm
    Link Great Image
  12. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    awesome!:thumb:
  13. wbdog206
    wbdog206 not me
    15 Jan 2007
    wow that is great.
    very good work.
  14. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    Dude this is looking fantastic , unreal, you must have hands like a surgeon!
    I hope the insides look as good as the outsides. Wicked mate keep up teh FANTASTIC work.
  15. ulysses Cazuquel
    29 Apr 2006
    Thanks Very Much MoRBiD for its letters of compliment
    Here more card covers made by me
    I will make plus come card covers and the best ones will be the chosen teams to be personalized with adhesives
    this week I make a guide of the start to the end of as to make cards covers of acrylic
  16. ulysses Cazuquel
    29 Apr 2006
    1 part
    In the acrylic to do the drawing of the pci cover using the original pci for later cuts using a disk of big cut preferably.
    In the acrylic to make the drawing of pci to cover using pci original stops later cuts using of preference a record of great cut
    2 part
    To do the finish using very fine sandpaper with it longs for in a flat surface.
    To make the finishing using well fine sandpaper with agua in a smooth surface
    To do light movements in horizontal and vertical directions ties to be with the flat borders.
    To make light movements in horizontal and vertical directions ties to be with the smooth edges
    3 part
    After the finish in the pci of acrylic, to go for the part of the frame, or be clue in the form of a pci.
    After the finishing in pci of acrylic, to go for the part of the frame, that is it leaves in the one form pci
    For that it is necessary a flat surface to be perfect the mold, gloves for not burning the hands, protection for not damaging the acrylic, something for clue the acrylic fixed and a Thermal puffer to mold the acrylic.
    For this a smooth surface is necessary to be perfect the mold, gloves not to burn the hands, protection not to damage the acrylic, something for leaves the acrylic fixture and a Thermal puffer to mold the acrylic
    4 part
    To do the demarcation in the acrylic to know the part that had modified.
    To make the marking in the acrylic to know the part that modifies
    Then with a protection over the acrylic and something that maintains the stopped acrylic começá to use the Thermal puffer ties that the acrylic is very easy of it molds.
    Later with a protection over the acrylic and something that the motionless acrylic keeps começá to use the Thermal puffer ties that the acrylic is well easy of molds
    Then it is only to do the mold well of light with the hand and care for not damaging the bent part of the acrylic.
    Later it is alone to make of the well light mold with the hand and care not to damage the folded part of the acrylic
    After the mold of the pci cover of acrylic done is takes advantage and to personalize with more some detail that can be a sticker or it does tie an engraving in the acrylic.
    After the mold of pci cover of done acrylic it is uses to advantage and to personalize with plus some detail that can be an adhesive or exactly ties an engraving in the acrylic
  17. ulysses Cazuquel
    29 Apr 2006
    The accessories that I will use to make a box where I will place the source in the part of low of the cabinet
    Tomorrow I will to begin the structure of box
    These parts are of aluminum with 1,5mm of thickness with 2,5cm of each side
    Here the 60 screws allen that I will use in my project having been that 60 screws with 4mm of diameter and more 40 with 40mm of diameter
  18. ulysses Cazuquel
    29 Apr 2006
  19. ulysses Cazuquel
    29 Apr 2006
    box aluminum by dremel
  20. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Dang! Really nice cuts there!
