Case Mod - In Progress Silverstone TJ11 Carbon.....Final pics
Discussion in 'Project Logs' started by kier, 6 Jul 2011.
  1. skullen
    skullen Minimodder
    31 Oct 2007
    Nice One kier like the carbon look :cooldude:
    Thinking of using this for my door panels :thumb:
  2. Scrappy
    Scrappy Mod in progress!
    10 Jul 2011
    I like the carbon stuff to have used it and seen it been used on minor things before bit I really like the stuff your doing with it.. Grey/Black with yellow... what can go wrong? Nice water cooling parts from what I have seen so far.. Can't wait for this to be finished!
  3. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Hehe, I'm on vacation ;)
  4. kier
    kier -----------------
    1 Mar 2011
    Thanks :thumb:
    Both side panels gonna be also with carbon
    Yeh but..............i'm on vacation and modding lol :D
  5. Nutman
    21 Oct 2008
    Hey, that's kinda funny - I'll be doing that very same combo from sunday and 7 days on, until my vacation ends. ;)
  6. samfgr
    samfgr techno : my life
    29 Jun 2011
    Wow looking great ! I look foward to the rest of this project :)
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I'm on vacation too, lol.... but still watching the updates on this :thumb:
  8. mnpctech
    21 Apr 2003
    LOL! You weren't kidding! :D
  9. dark4181
    dark4181 Ero-sennin-tebayo
    3 Jan 2008
    Subscribed. I've been waiting to see what a skilled modder can do with this case :)
  10. kier
    1 Mar 2011
    Update
    Now that I have the REIII I can not stay behind in order to coat it with carbon. Before I'm going to do this, there is some treatment needed.
    If I stick the carbon film without doing this, you will see the holes where the bolds are in
    That's why I’m gonna cover the holes. What we need:
    Detergent
    Ammonia with some cotton swabs
    And some silicone sealant
    First I have cleanedand degreased the holes and bolts
    Then the put the sealant in it and smoothed it with detergent on the finger
    When everything was dry I put the carbon on. Heated the carbon with the heatgun to get the Straight edges
    Cut the edges and lines with a sharp knife
    Then it was time to treat the motherboard. Screwed the The original blocks off and used a cleaning kit to clean everything
    Arctic Silver ArctiClean Reinigingskit
    A few drops
    And it's clean
    Placed the Waterblock
    Finished
    I also changed the cover of the radiator, as I need to have optimum heat dissipation. That's why I cut a 120mm hole next to the radiator
    This fan will blow the hot air out from the lower compartment
    To still stay a little original , I’ve have made a custom midplate, this will be covered with yellow acryl
    1mm Aluminum plate
    First tape it and marking it
    Total shot coming up. The air intakes in the side panels are in my opinion not pretty, but it offers a possibility to use it for 2 aquaero's
    Made a bracket and fitted it with an old Aquaero
    For this one also created openings for the midplate that still has to be bent. I had hoped that I already could showed, but I'm still waiting for my new little folding machine
    Then placed the two Aquaero's VF
    Placed the midplate in front
    Also placed the side panel
    To get smaller recess in the side panel I have a made a piece of aluminum and marked it
    And made this also with openings in the size of the display of the aquaero, s
    These I put on the inside and on the outside I have made another piece
    This I have made as tight as possible because there wil be later on carbon on it and I do not want to have ugly edges visible. Just put a little bit carbon on it to show what the intention is
    Soon as I'm going to do the whole panel, and maybe I’m gonna place another acrylic display for it
    Am also has been busy with the hardware and the WC stuff. Gonna place the reservoir at the back. For this there are coming 2 x EK-DDC X-RES with 200mm reservoirs
    To see how it will look i’ve placed them like this
    Fits tightly next to my Corsairs
    Placed the two GTX480, third one is coming. Still gonna do someting with the gpu’s
    Now there are nickel backplates but these will be exchanged with black ones
    Nice to have Corsair
    Tuesday my folding machine is coming and I can finish the midplate
    That's it on my last day of my vacation, tomorrow back to work ........... unfortunately
    Updates will now take a bit longer
    Grtzzz.
  11. LazyMan
    LazyMan What's a Dremel?
    9 May 2010
    Looking awsome, thanks for the update.
  12. Nutman
    21 Oct 2008
    Nice job on the mobo block.
    Oh, and Aquaeros rule - got one of those bad boys myself.
  13. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    really loving the build. isnt that carbon stuff just the best!!
  14. kier
    1 Mar 2011
    Thank you for the reply ;)
    Really love the Aquaero's, I'm always use these in my mods :clap:
    Hi Stem83 thnx, This Carbon is great, really nice to work with :dremel:
  15. mnpctech
    21 Apr 2003
    I love watching how meticulously everything is executed kier. This would be the PC I would want to own :thumb:
    for anyone else interested, 3M Di-Noc Carbon fiber is one of the prizes we offer for bit-tech's MOTM. It's not a vinyl film, it's described “synthetic textile” It’s a flexible and lightweight carbon fiber vinyl film that looks like the real thing, only less expensive. It can be installed on both flat and curved surfaces. I made a video tutorial here
  16. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I'm loving it so far :)
  17. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    great job so far kier, loving the log and looking forward to the next update, i'm subscribed :)
  18. kier
    1 Mar 2011
    Small Update:
    This week i've got my little hightech folding machine, real nice addition to my tools
    Ok, lets bend something,
    And the midplate part one
    And sawn the midplate part two from the yellow acryl
    And put it al together
    Everything is gonna be poadercoated later on
    And next step is to measure al the slots for the cables and the WC
    To be continued ;)
  19. Huge
    Huge aka Dave
    11 Jul 2011
    Wow, this looks like a great project. Looking forward to more updates!
  20. KidMod-Southpaw
    28 Sep 2010
    Lol, the temp monitor says "pomp 1"
    Very nice work, love it!
