Sony vaio Error
Discussion in 'Tech Support' started by Graffix, 5 Apr 2006.
  1. Graffix
    Graffix What's a Dremel?
    5 Jul 2005
    hey well i was playing around on my sony vaio all in one computer, and it prompted me to restart so i did and now the computer comes up with a error at startup saying cannot load operating system. This has left me confused and im not sure what to do. any help would be really appreciated as i need the computer for my job.
    Thanks in advanced.
  2. Krikkit
    21 Jan 2003
    What's the error it comes up with (exactly)?
    What did you change before the restart? Do you have a recovery disk that Sony gave to you? Have you backed everything up recently? (You might have to start again).
  3. Graffix
    5 Jul 2005
    the exact error is "error loading operating system"
    hope that helps. :duh:
  4. Graffix
    5 Jul 2005
    i was playing around with the hard drive partions, i dleted one to try and increase the size of another. i made sure there were no OS files in that partion but it must have deleted something.
  5. DaSuperFly
    DaSuperFly What's a Dremel?
    19 Apr 2002
    Oh dear...using Partition Magic I assume? Got to be careful with that, with powerful tools comes great responsibility. Has the computer got a floppy drive?
  6. Krikkit
    21 Jan 2003
    Ah. Sounds like you simply deleted your partition then.
    Do you have a recovery disk from Sony? That might work.
    Otherwise you could have a look on download.com for a partition editor to un-delete your partition and hopefully recover it...
    [edit]Damn... Super beat me to it :( [/edit]
  7. Arkuden
    Arkuden mow?
    9 Jul 2004
    probably messed up your master boot record or MBR. Try booting to a win98 startup disk and type the command fdisk /mbr worked for me when I did that with linux last year... that or you will need to use xp recovery console.
  8. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    It could be that the partition you deleted was the active partition whee the windows bootloader was installed.
    Try downloading a bootdisk with fdisk on it (Heres one: http://www.mbhs.edu/~jaosborn/boot98se.exe). Open fdisk and set your windows partition as active. Then, exit fdisk and type 'fdisk /mbr'. That should re-install the bootloader.
    Although I'm not 100% sure if that works with windowx 2000/XP, but it should.
    Edit: Beaten.
  9. Graffix
    5 Jul 2005
    ok im going to look for his restore cd. lets hope i find it ...
  10. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Can also do it from windows 2k/XP (if you're using that OS) recovery console.
    Boot to the console, and type "fixboot" and "fixmbr" (there may be spaces after the "fix" part, can never rembember!!)
  11. Graffix
    5 Jul 2005
    yes its a windows xp system. i think ill have a go at that but will i need a recovery disk to do so ?
  12. Krikkit
    21 Jan 2003
    It's on the setup disks for 2K/XP, it's an option when you start it up.
  13. Arkuden
    Arkuden mow?
    9 Jul 2004
    yup once it has loaded all the files you have the option to hit enter to install windows and you can press R for recovery console. Recovery console may ask you for an administrator password though, so hope you remember it or just hit enter if its blank.
    do you know which partitions you deleted?
  14. Graffix
    5 Jul 2005
    the largest of the three (200 gb)
  15. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    Ouch
    Try get hold of a linux live cd and you should be able to fix the mbr from there.
