Case Mod - In Progress SR-2 STACKER - 'Completed'
Discussion in 'Project Logs' started by coolmiester, 21 Aug 2010.
  1. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    The antec truepower quattro is an IDENTICAL power supply to the EVGA one, you could just get that :)
  2. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Three Kazemaster fan controllers turned up for the rad box so time to make a bezel to hold them.
    Just wish they had turned up earlier so i could have got them all mounted but ran out of time so one down, two to go and at least the weather is going to hold out all weekend so more to come over the next few days.
  3. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    I've got the exact same controller, it's a good bit of kit, apart from the bloody alarm if a fan is turned off/on.
  4. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    3 controllers what for??
    IF you are going to use 12 fans , an aquaero would have been the best solution, and there are other fan controllers that could have been used also , such a waste of space in the case and in my opinion many controllers in a case front gives an awfull look , anyway i like the project your building keep it up !
  5. TARIKK
    TARIKK Minimodder
    19 Feb 2009
    This one might be a good choice as well. It allows 30W per channel which means you can control something around 70 :jawdrop:, 120mm fans.
  6. coolmiester
    31 Dec 2002
    Cheers guys but seriously the hardware isn't up for debate :sigh:
  7. rjkoneill
    rjkoneill What's a Dremel?
    11 Feb 2008
    looks sweet coolmiester
    really liking the custom plate for the controllers
    what finish are you going for on the plate?
  8. coolmiester
    31 Dec 2002
    Reservoirs TBA
  9. coolmiester
    31 Dec 2002
    Oops, missed a couple of pictures out!
    I used my trusty Fret Saw with piercing 12 x 32tpi blades for the cut outs :)
  10. Yaka
    Yaka Multimodder
    26 Jun 2005
    Is that normal hand saw?
  11. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    it's a generic Fret saw, Yaka.
    What are these carbon black fittings you speak of, coolmeister?
  12. Yaka
    Yaka Multimodder
    26 Jun 2005
    nice, wish i was able to cut so straight like that
    anyways very nice work all in all cant wait for more updates:)
  13. coolmiester
    31 Dec 2002
    Yeah, Matt's right, just a generic Fret saw though i've never used these tiny blades which seem to have a mind of their own so you got to be super careful especially on straight lines but give a great sense of satisfaction to know you made it yourself and not taken the easy option.
    I'm just checking with Bitspower to make sure i didn't over step the mark and will update on the Carbon Black fittings ASAP
    Waynio likes this.
  14. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    whoopsie :p
    A nice blade to use is a generic carbon coated one, intended for tiles. Makes really nice cuts with hardly any filing. Used it before on a few bits.
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    :jawdrop: OMG & wow, ludicrous amounts of awesomeness :clap:, some serious money going into this :eeek:, so this is the face of budgetless modding, Niiiiice ultra enthusiast pc, awesome :D :thumb:.
    Your doing a great job so far mate, this is like a pc I can only dream of doing, thanks for sharing a dream pc to make us all drool :D.
    I checked out your other mods & they are all very nice :rock:. +rep +subbed :thumb:.
  16. coolmiester
    31 Dec 2002
    WeeeHeeeeeeeeeeee:lol:
    Finished the bezel for the rad box which worked out good even though there is a few slight imperfection - fan controllers are just stuck in with Blu Tack for the time being and the whole thing still needs powder coated and painted but that's it pretty much done :)
  17. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    That looks awesome man! Love it!
  18. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    will you be using felt tips to colour in the bluetack? :p
  19. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    mmm so hot! loving the slight bevel you got on the display cut out dude ;)
  20. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    Coolmeister, chance of the measurements you used here? I'm building a new front panel for my pc, and this is how it'd look (minus 2 of the controllers)
    Got the exact same piece of kit (y)
    Looks epic with the bevel.
