Case Mod - In Progress StarCraft II: Protoss [CM Cosmos] - Nearly completed
Discussion in 'Project Logs' started by Koradhil, 22 Oct 2007.
  1. Noobkiller
    Noobkiller What's a Dremel?
    11 Jun 2006
    oh snap! Nice job
  2. Stievius
    Stievius Industrial Design Student
    12 Nov 2006
    Now that are some daring colors ;)
  3. Krikkit
    21 Jan 2003
    That looks really nice - a great, simple mod so far. Lovely. :D
  4. teetree
    teetree What's a Dremel?
    3 Nov 2007
    That blue is awesome , when you paint do you just use cans?
  5. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Yes, I use regular 400ml spray cans from Motip. The entire frame was painted using just one can of metallic blue/purple.
  6. Koradhil
    9 Nov 2004
    Mesh for the top panel, cut to size using ordinary scissors.
    Mockup with DD Fillport.
    Sprayed the mesh and cut a hole in the plastic panel for the fillport.
  7. Colossous
    Colossous Minimodder
    28 May 2007
    Liking the mesh dude, are you going to be spraying the mesh in the side pael window the same colour ?
  8. Koradhil
    9 Nov 2004
    Yes
  9. Colossous
    28 May 2007
    Sweet dude, you got idea's for the usb etc mount on top ?
  10. Godric
    Godric What's a Dremel?
    23 Jan 2007
    Looks nice :) I really like that type of mesh. If it works without scratching the paint every time you open it, you might want to spray the bolt in your fillport yellow as well.
  11. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    looking really good. That mesh you painted blue = awesome!
  12. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice work! :thumb:
  13. Koradhil
    9 Nov 2004
    Front panel: black
    Yellow sides...
    Mesh:
  14. Guest-23315
    Guest-23315 Guest
    Looking fab.
    I know you love your spray-paint (and your damn good at it too by the looks of things), but you really must try power-coating once!
  15. Colossous
    28 May 2007
    Very cool dude ! :thumb:
  16. Koradhil
    9 Nov 2004
    Varnished the front panel and sprayed the mesh blue.
    I'm working on the CPU waterblock. I wanted to use a Scaro UV blue waterblock (similar to an Alphacool NexXxoS XP Bold but with UV blue acrylic). The original cover was for Socket A / Socket 939, but it was too big for my Socket A board (interference with IO ports), so I had to make a new cover. I intended to use UV blue acrylic, but I only had 5mm lying around which was too thin. Therefore I used ordinary 8mm acrylic.
    Drawing...
    And done.. sorry for the lack of action shots.
  17. Koradhil
    9 Nov 2004
    The project is now nearly completed. I still have some small things to do like wiring, gluing the mesh on the frontpanel and spraying some parts such as the window mesh and the hdd cages. The project has to be done by november 23rd. Today I did a photoshoot. All these pictures are clickable :thumb:
  18. sik19
    sik19 What's a Dremel?
    2 Jan 2006
    Hmmm looks very clean to say that from the beginning, but i have expected a bit more. Imean you didnt had much time, but somehow i miss sth that gives me the feeling that im looking at a Computer designed and used by Protoss.
    But i believe if you have had more time it would have turn out as great as your other projects.
    sik
  19. rito
    rito What's a Dremel?
    19 Sep 2007
    Looks really good! But won't the mesh let a lot of dust in?
  20. Koradhil
    9 Nov 2004
    There will be acrylic behind it, obviously ;)
