Suitable for 24/7 Operation
Discussion in 'Watercooling' started by Modsbywoz, 5 Aug 2020.
  1. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Staffs, Just Outside Mordor.
    I am putting together plans on a rater in-depth mod and wanted to ask for anybodys experience on watercooling.
    Would it be okay to run a watercooled rig 24/7 using distilled water and treatment following a ragular maintenance check and replacement fluid every 4 - 6 months?
  2. Xlog
    Xlog Minimodder
    16 Dec 2006
    Vilnius, Lithuania
    IMO, unless you really like WC maintenance, there is really no point in replacing fluid every 6 months (unless using some sort of coloring agents, those dont tend to last long), the longest I ran without touching the loop (24/7/365) was 5+ years. ~10% antifreeze + distilled water is my go to solution, most "pc watercooling" additives are pretty much just overpriced antifreeze.
    Bloody_Pete likes this.
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Guildford born, Bristol living
    Well, they have gavanic corosion inhibitors and stuff like the EK one lubes your pump better. But year, I've run distilled and deionised water + silver kill coil for 5+ years, EK's clear premix for around the same (that did produce a but of white residue in the Res but nothing in the blocks). 4-6 months is a bit OTT, and you'll soon get bored of bleeding bubbles :p
  4. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    telford ..uk
    Tbh mate buy the pre mix fluid I have 2 280mm rads a cpu block and a res and I ordered 2 litres and I've only used 3/4 of one of them and you get all the benefit of the pre mix.
