Peripherals Test long LAN cable in situ?
Discussion in 'Tech Support' started by Picky88, 21 Oct 2013.
  1. Picky88
    Picky88 What's a Dremel?
    18 Apr 2010
    Stevenage, UK
    OK So I am trying to diagnose a problem where the internet hangs for a few seconds, and then works fine. When I ping my adsl router I sometimes the request times out, most of them time it is 1ms ping.
    I am connected to the router via a fairly long LAN cable that is routed through the house, and has been soldered in a few places, so I think this is the most likely culprit. Is there a software based test I can do to isolate the cable as the issue?
  2. TheMadDutchDude
    23 Aug 2013
    Broadview Hts, OH, USA
    Soldered cable? Uh ooh. I sense there may be some form of interference coming in from there as they are no longer shielded.
    I may be wrong though.
  3. Picky88
    18 Apr 2010
    Stevenage, UK
    Well none of the wires are shielded, its only a twisted pair cable. The cable is slightly untwisted at the soldered point but only for a few centimetres. It is also possible that the cable is pinched or damaged somewhere along the route, so I only want to go looking for problems if I am sure it is the cable at fault!
  4. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    UK
    Are you able to move your pc next to the modem/router or use a laptop and connect via Ethernet to test?
    I would be 99% confident in saying that the cable is the issue, and you will probably need to run a new cable.
  5. Gareth Halfacree
    4 Dec 2007
    Bradford, UK
    That's enough. You can't just solder two lengths of twisted-pair cable together and expect it to work, sadly. The twists in the cable are there to eliminate cross-talk: untwist the cables and you've got a problem. You're going to need to run new cable - I'm guessing the 'hanging' is packet loss.
    Run a ping test like so:
    ping -t routerip
    That'll ping your router continuously until you cancel with Ctrl+C. Let it run for a half-hour or so, then hit Ctrl-C (or Ctrl-Break to keep running but display statistics) and see what the packet loss is. If the cable's fine, it should be 0%. If not, run new cable - and don't solder it this time!
  6. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Cambridgeshire
    Only real way to test it correctly would be with a Fluke or something similar.
  7. jinq-sea
    15 Oct 2012
    London, UK
    Might be easiest just to use the knackered cable as a draw wire and pull a new cat5e (at least) through in its place...
  8. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Brighton
    I would do this, easiest way to get a new cable into an old run if you are going to be removing the knackered one, and run 2 runs, just for kicks but then you have more options and some movement to expand on anything in the future, plus, you might as well if you are pulling through one new cable.
  9. jinq-sea
    15 Oct 2012
    London, UK
    That's a (Margon) Man with a plan. I meant more than one when I said (at least). Damn my lazy typing and Margon for showing me up ;)
  10. Picky88
    18 Apr 2010
    Stevenage, UK
    I set a ping command running, and then went and wiggled the cable joint, lots of ping timeouts. So looks like thats the problem.
    Having another look at the cable it has actually been soldered in two separate places, as a bodge because the connector is too big to fit through the holes in walls etc for the cable. I think I need to sort out a new cable, I will go for a cat6 one given how cheap the cables are, also I believe cat6 cables are shielded which might make the cable more robust if it gets pinched somewhere.
    Motto of the story if you do a job in a hurry you will end up doing it again! I never seem to learn that one!
    Thanks for input as usual,
  11. Margo Baggins
    28 May 2010
    Brighton
    oh man I didn't even realise you wrote at least :p
    I was more enforcing your good idea :)
    No showing up, more, agreeing with your master plan!
  12. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Behind J00 sumware, London
    Are you going to crimp the connectors yourself?
  13. Picky88
    18 Apr 2010
    Stevenage, UK
    I was planning to drill the holes in the wall out bigger so that I can fit a cable with the connectors already fitted.
  14. keir
    keir S p i t F i r e
    5 Oct 2003
    Middlesbrough | UK
    Where's a good place to get a reel/long length of cat5?
  15. Margo Baggins
    28 May 2010
    Brighton
  16. jinq-sea
    15 Oct 2012
    London, UK
    Crimp the connectors yourself (if you feel confident enough to do so) and it'll require a) a smaller hole and b) bespoke lengths!
    Margon - good idea fistbump :D
  17. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    lost in the middle of lincolnshire
    don't put ends on, put sockets on the wall, much better and more reliable
  18. Picky88
    18 Apr 2010
    Stevenage, UK
    Well the cable goes through several walls, all of which are brick so it would be quite a big job to do. I think If I buy a cable with connectors already on and I am careful not to give it any sharp bends it should be fine. Our adsl connection is only 2mb so I hardly need the cable performing at peek speeds.
  19. keir
    5 Oct 2003
    Middlesbrough | UK
  20. Picky88
    18 Apr 2010
    Stevenage, UK
    Not having much luck with LAN cables this week! I have noticed the cat5e cable going to the garage connects at only 10mb, one end is a router with gigabit ports and the other is a computer with a 10/100mb port. If I change the ethernet card settings from "auto" to "100mb" it says ethernet cable unplugged, so it looks like this cable is damaged somewhere aswell.
    I have seen some ethernet cables that say they are suitable for outdoors, I guess I should get one of those, or look for a reel of outdoor lan cable and get a crimp tool given that I now have two cables to sort.
